Monstaliner question
baldilocks
Battle Ground, WA
GOLD Star
Battle Ground
Has anyone applied their second coat of Monstaliner the next day? Their info is a bit contradicting if you compare their FAQ's to the instructions with the kit.
I am asking because my prepping is working out that I could apply a coat in the early afternoon today but the it's only going to be 60 degrees today so I figure it will need extra cure time to re-coat so I was thinking about leaving it cute over night and apply coat two Monday morning.
Any experience with Monstaliner application over a 24 hour period and also your experience with cure time at temps between 45-60 degrees would be appreciated.
You doing the whole truck?
Top to bottom. Going to tint it the factory 045 white.
No experience with 24 hours but I started prepping mine on an afternoon just about 50* but didn't get to applying until the evening when. It dropped into the low 40's and into the low 30's by the early AM when I was finishing. Didn't seem to have a single problem curing. I would recommend scuffing if you're applying after cured to a hard surface finish. I was going to do the same thing as you but with raptor liner over my Monstaliner because raptor can be sprayed to almost smooth...just a light orange peel texture. I want only the bottom third to be textured and the rest to be relatively smooth like a regular paint job...a super tough paint job.
I tried to do it the next day. Didn't work out very well and we needed to buy an additional gallon to do another coat to days later. Our problem was that the first coat was still too tacky and didn't scuff correctly. This made the texture of the 2nd coat not look right.
We ended up waiting a whole week, going through all the prep, then adding two more coats. Looks way better now. Here are some lessons learned from out project:
  • Go Slowly!
  • One person apply paint then another person with a cleaner roller smooth it out. Its hard to get good coverage if your roller doesn't have enough paint but then the loaded roller makes s***ty texture. We did one panel at a time this way and it came out way better
  • Make sure the final roll is in one direction and consistent for the entire truck. Looks weird otherwise.
  • Use one fresh roller per panel to avoid leaving behind bits of roller.
  • Take your time taping
As I read your post it would seem as though you were applying Bedliner after dark. Where did it sit to cure?
My slightly undersized unfinished single car apartment garage.
Don't wait, as said above it will be tacky. please buy like 10 extra rollers as the stuff dissolved mine and left little blue chunks in my paint.
I have 8 rollers and plan to wait to start rolling tomorrow morning because the wine is beginning to work its magic.
I sprayed mine in 60-70 and only gave about 10 min inbetween coats. By the time I finished one fill can twidel thumbs and start back at it.
Spray and there will not be an issue. prep took hours spraying 4 coats only took and hour or less with undercoating gun.
I've done 2 different applications one time it rained over night about 5 hours after spraying no affect
Woke up at 0500 and did my push-ups then walked outside to begin the final preparations before two coats of Monstaliner and, much to my surprise, it's fxxxing raining! Rain was not in the forecast yesterday. It's about 0800 now and has stopped raining but I think I will roll this Bedliner on inside my garage just to be safe.
Damn that sucks!
But it will probably be better off on the garage anyways. I can't wait to see how it turns out.
Damn that sucks!
I'm still putting metal tape over the flare holes. This is taking longer than I anticipated.
Lighting in the garage is not uniform and that bothers me. Hmm?
Hmmm, does this mean it's time for a garage lighting upgrade?
Yes. And 230 V for a better welder.
