- Joined
- Jul 20, 2004
- Threads
- 274
- Messages
- 23,204
- Location
- Chandler, AZ
- Website
- www.tontorecreationalliance.org
Unfortunately , unless you've got a very high tolerance leveling belt sander - none of them will provide a flat surface . ...
Agree, could be argued that most lathes and mills will not get them perfectly flat. If they were, would not need gaskets. Most manifold and carb bases are nowhere close. The point is flat enough to do the job. A buddy is an aerospace machinist, loves to poke fun at what automotive guys call precision.
I have a lathe, mill, granite surface plate, straight edge, etc, IMHO, overkill for the job. Have played with, made rocket motors, hydraulics, etc, thousands of psi, temp change, in comparison, sealing a carb to a manifold is pedestrian, simple. If you want to be all of that, groove and o-ring them, again totally overkill.
Maybe it's the desert environment, but have see lots of them rock hard. Another way they get damaged is ham-fisted users prying them off. In my experience, flating them and replacing the gaskets has always been successful.
