Have had an intermittent code 25 and 26 since I bought the truck. It recently ran rough when shifting into 4th gear @ 45 mph. Then it developed into running rough all the time.
I pulled the spark plugs and most have oil on the threads. The electrodes look good accept cylinder 6 which has oil on it (two attached photos).
I did a compression test and that cylinder (#6) had the best compression.
#1 - 180
#2 - 175
#3 - 150
#4 - 180
#5 - 150
#6 - 190
I believe the distributor has an oil leak and #6 is on the bottom of the distributor cap which the oil accumulated around. I don't know where to go next. I'm about to change the #6 spark plug to see if it fixes the misfire.
#1 - 180
#2 - 175
#3 - 150
#4 - 180
#5 - 150
#6 - 190
