Misc Torque Specs - Use at your own risk! (FAQ)
This is all very helpful. I have never been accused of being a mechanic. That will probably not change. At least I have now begun the process of getting educated before I attempt to effect a repair/replacement. The forum and its contributors are really a tribute to the willingness that many people have to help others. It is refreshing.
Curious… anyone know the difference between flywheel bolts and fasteners? I take it fasteners are the bolts that mount the flywheel to the crank and should be torqued between 58-79 ftlbs…
Flywheel Retaining Fasteners
58-79 foot pounds
Flywheel Bolts
47-51lbs (FSM)
OME (Old Man Emu) anti-inversion shacle instructions with torque specs.
OME (Old Man Emu) fixed greasable spring pin instructions with torque specs.
Wondering if anybody knows what the proper torque is for the transmission side cover bolts for a '74 FJ40? The cover is leaking on mine and I am changing the gasket. I can't seem to find it in the Haynes manual and I've tried searching on here but haven't found anything. Thank you.
I don't think they need a lot. Make sure both surfaces are clean and the plate isn't warped and is flat. If the gasket has any fiber I soak it in warm water for 15 minutes to soften it up a little so the high spots can dig in easier. You could lightly apply apply some sealant to both surfaces for added protection. I like the Permatex Aviation B non hardening myself.
I have seen a chart with general bolt torque spec's by bolt size.
From the thread PTO Cover Bolt 11 f/lb
Thank you very much. I figured they wouldn't need much. I intend to make my own gasket using Fel-pro Rubber-Fiber gasket material and was thinking of adding a thin coat of Permatex High Tack sealant to each side.
I’m a big fan of even just using blue RTV on paper and cork gaskets. Then I let it tack up for 5 minutes before torquing. Helps reduce leaks and nearly eliminates any scraping when you go back in.
