For Sale Misc Land cruiser Parts (Virginia Beach)
Virginia Beach
Misc Landcruiser part:
Rear heater core: $50.00 plus shipping,
Aluminum door catch $50.00 plus shipping,
Door hinge brackets (attaches to body, not door) powder-coated, $25.00 plus shipping,
cable assembly mounting (from a 72 cowling) powder-coated, $25.00 plus shipping,
Diamond side panels $100.00 local pick-up only
Doors. Windows intact and operate $400.00 local pick-up only
Fender markers $100 plus shipping
for pair
Windows intact and operate $400 local pick-up only
Do you know for sure that it dose not leak?
If it is good I will take it.
Also your PM box is full.
I am assuming you are talking about the heater core. I will check. I will put a rubber hose around one end with a hose clamp, and then use the portion of a bike tube with Schrader valve. i will pump it up to see if it holds air and submerge. Other than that, I do not know how else to check.
only need about 10 PSI
PM’d you
Any luck with the test..
I was not able to do an air test, however I did fill a bucket with water, plugged on hole and blew air in the other. It does leak. Im not sure if it can be repaired. If your still interested, I will sell for $10 plus shipping. Ted
Some can be fixed, is the leak on the outside, if so it is easier to fix, but they are expensive to fix-if fixable, I will take the gamble...send me an email and I will give you my mailing address for shipping and payment method and info, thanks
