- Thread starter
- #21
More frames:
1- Air filter is new, no vacuum leaks that I can see. Spark plugs were replaced by previous owner not too long ago.Did you repair wire and check for more rodent damage and repair any found. That's what I do first. Then clear DTC see what returns. If O2 DTC returns:
- Tune up. Air filter. Make sure no vacuum leaks, all spark plug tight or replace them. Clean throttle body.
- Run a full tank of gas with a fuel system cleaner. Such as: 44K (2 cans), Chevron Techron or Sea foam.
- Then perhaps a CAT cleaner like, Cataclean.
- Do some Italian burns, AKA High RPM run.
- R&R BK1 S2 (rear O2 drive side) if DTC returns. Either Toyota Denso, or Denso. Note: Many opt do both side at same time.
Well poop, lol. Too late, ordered the OEM ones from Toyota of Decatur for $545.00 out the door for all four . Honestly the total difference was only $150.00 between OEM and Denso. Also there are four different part numbers from Toyota and only two from Denso.I used Denso and haven’t had any issues.
