Mid 80's 2F rebuild candidate
Cottonwood, Az.
Are there any reasons that a 2F out of, say, an 85 FJ60, would NOT be a good candidate for a medium performance rebuild? Or to ask it a different way, is there anything that would make a later 70's 2F more desireable to rebuild than an 80's 2F or vice-versa? I'll ask nicely, don't bust my balls if this is a stupid question!
The only reason it would be a poor candidate is if there is a rod through the side of the block, or a crack in the head.
Otherwise, mid'85-later has all the best stuff:
flattops, close chamber, lightweight block, lightweight rods, lightweight valvetrain, oil cooler, aluminum WP and clutch fan, big electronic distributor, threaded oil gallery plugs, 3-piece thrusts, yadda, yadda...
Did you just use the term "lightweight" with a cruiser motor???
Don't mill the head to up combustion ratio. That's the poor mans way to get a higher ratio and it works short term. Long term you are asking for trouble. My $0.02.
What vehicle are you putting the 2F into? Your FJ-55? The 2F in my '55 is out of an '84 FJ-60.
If you need a rebuild kit PM me.
Seth
andrewfarmer said:
Get the head off an F with matching piston style and you get an instant compression increase with no machining.
That is 74 F only BTW..
Kinda hard to find.
Good news. PVCRUISER, I don't understand the short term thing about the head milling. I've heard of lots of people doing it without any trouble.
Andrew, if I found an F head (74?) would there need to be work done on the oiling system? Whats the difference in size of the combustion chambers. I'm thinking of having the combustion ratio in the 9 to 9.5 area.
The oiling issues are the reason you go to a 74 F head.
the last year of the F they made it with a intergal oiling system like the 2F. Not the wire style.
Search online. there are lots of calculators out there.
Yes. They took a bunch of excess crap off the head, block and bellhousing castings, comparing a 76 to an 86. Just the cylinder head lost 10-15 lbs, dropping from 100+ to 90-, block a similar percentage due to thinner castings and removal of some obsolete casting bosses. Valvetrain loses a few pounds w/ lighter stands, rockers and pushrods. Bellhousing finally loses all the extra reinforcement for the non-existent BH motor mounts. It's not a big change in overall vehicle weight. But if the choice is there, I'll leave the excess weight on the scrap pile.
If you're ever bored you can teardown an early and a late 2F side by side, and plainly see the differences in the bare castings.
Apparently I was bored.
:cheers:
