ARCHIVE Miami, FL: 1 x Nitro Gas 2" Suspension Kit - Suited For Toyota 70 / 73 / 74 Series Land Cruiser
Asking $1,150 or best offer
1 x Nitro Gas 2" Suspension Kit - Performance Load (0-440LBS) Suited For Toyota 70/73/74 Series Land Cruiser
New this kit is $1,449 PLUS shipping (see below link):
I bought this for a 70 series I imported but sold the vehicle before I had time to lift it.
This Kit Includes:
TOY008B - Front Leaf Springs - Medium Load 0-220LBS
(2) TOY007BN/S - Rear Leaf Springs - Medium Load 0-440LBS
(2) 12637GR - Front Shock Absorber - Nitro Gas
(2) 12650GR - Rear Shock Absorber - Nitro Gas
436UBK - Front U-Bolt Kit (2)
415UBK - Rear U-Bolt Kit (2)
719UK - Front Polyurethane Spring Bushing Kit
(one set)
719UK - Rear Polyurethane Spring Bushing Kit (one set)
Ironman 4x4 Nitro Gas Suspension Kits make a big improvement in ride quality, stability, strength, and handling over the stock suspension. Perfect for outdoor adventures into the backcountry and back home again without breaking the bank.
Specifications:
Estimated Lift: 2"
Package Details: Kit
Pressurized shock absorber boosts performance and adapts to a wide range of driving styles.
NITROGEN GAS PRESSURIZED - Low pressure nitrogen gas dramatically reduces the likelihood of oil aeration and shock fade.
35mm TEFLON BANDED PISTON - Precision shim-stack piston specifically valved by Ironman suspension engineers, banded with teflon for smooth long life operation.
54mm TWIN TUBE BODY - Increased oil volume for improved cooling and endurance, Twin tube construction protects internal components from rock damage.
16mm – 18mm HARD CHROME PISTON ROD - Hardened and polished, volumetrically balanced to piston size.
FLEXIBLE RUBBER BUSHES - Offers quieter operation and reduces damaging side loads from shock absorber.
TRIPLE-LIP HIGH PRESSURE NOK SEAL - Maximum gas and oil retention ability to withstand high displacement offroad use.
SUPPLEMENTARY WELDED MOUNTS - Fusion welded and supplementary welded for maximum strength and reliability.
SINGLE PIECE BILLET EYE RINGS AND STEMS - Ultra robust design prevents breakage or bending of mounts.
VEHICLE SPECIFIC VALVING - Every part number is specially valved for each vehicle application, this ensures the best possible ride and handling as intended by Ironman suspension engineers.
LONG TRAVEL - Suitable for standard and raised height vehicles, additional length increases wheel articulation.
IMPACT RESISTANT STONE SHIELD - Steel or Polyethylene dust shield protects piston rod from impacts and road debris.
