does it have 4 cilinders and 3.4 litre engine with 1 valve cover ? (then its a 3B) if it has 4 or 5 little valve covers you have a vm4 or vm5 which is not good !
I you have the original springs, they're likely shot!
the bumpstops are bolted to the shassis,what the normal distance between them and the axle sould be i dont know.
But did you have leafspring suspension before? because even in new condition its way harder then coils.
Nice rig mate, if you need suspension in Spain try TMX 4x4, ask for Andres and tell them Leighton from Dobinsons sent ya
C/ Roma 1, Nave 29, Pol. Ind. Puerta Madrid
28977 Casarrubuelos (Madrid) Tlf.: 918 133 626
www.tmx4x4.com
30 43 1197 E, 44 47 751 N, Altitud 622m.
First mod - install car seats. Three wide does just barely fit. For anyone interested these are Britax Frontier Click-tights.
My kids now expect me to pick them up from school in "the Cruiser".
suspension seats may help with your ride if you do not already have.
I ended up taking as much as I could off of it.
And this, the crown jewel... H55F and t-case. Thanks to @AlbertoSD 's thread I believe it has the H/F input shaft so hopefully I can swap it later for my 3B.
I also pulled the instrument cluster because I wanted a tach mainly. Come to find out that the VM spec trucks are 12V and I'm obviously 24V.
Please go back and get the roll cage!!
It'll dismantle into smaller pieces that, I'd think, coujd be shipped DHL. Worst case, I'll see if Alberto can fit in his carry on next trip to Spain.
You might pick up the thirds, too, for your own purposes.
It's H/F shafted, for certain.
If it's been reasonably well maintained, it should be well worth your efforts, because the craptastic VM put out ~50hp, had 4.56s to compensate, so nearly impossible to overwork the H55F.
What came behind mine was the smoothest shifting H55F I've ever felt......until I rebuilt it, when swapping input shafts.
Don't know anything about 3B tach sender, but the VM is the same as F/H, with pickup on flywheel.
It might not read accurately, but if 3B similarly sends, it could be possible to adapt, swapping relays and lights in the cluster.
Don't think there's much thinking going on in cluster. Speedo is cable driven, tach merely senses pulses provided, registers on gauge. Lights could be swapped to LEDs, so don't know why it wouldn't work......but basing that on having both clusters and harnesses on the bench, trying to do the reverse swap, with absolutely no experience in doing.
Became more determined to get the original tach to function with an HZ, which is low on the priority list, at the moment.
Did you have a problem with the rebuilt tranny after you swapped the input shafts?
