Methodical first start process?
If the idle fuel passage is clogged, fuel will be pulled from above. You don't want that. The primary booster/nozzle should be bone dry at idle. I'd want to figure out why fuel is dripping from above. Can you remote start with no choke and watch for fuel dripping in either barrel?
Could try pulling the idle air mixture screw, give juice to solenoid, squirt carb cleaner in air mix hole then blow compressed air:meh:
Double ring booster = nozzle, or venturi. Most carbs have a single ring on the secondary. The choke fast idle will set the idle speed at cold even if the choke is partly open.
Ummm, can you dumb that down for me? Is it a problem to have what I have? The truck came to me like that 20 years ago, and I drove it thousands of miles this way?
Thanks for sticking with me. I am charging up the batteries again and taking a rest (beer.) The barrel may be wet from "spitting" I occasionally get while I am trying to get it running. I can easily plug my remote starter again later and watch if any fuel is coming out the top nozzel.
I looked for and didnt find any vacuum leaks. I pinched off the crankcase PCV to the carb spacer intake and checked the carb linkage and distributor advance arent leaking air. Its desmogged so those are the only intake leak options.
This afternoon I had started the idle throttle screw at just touching the lever. Motor would fire immediately but not run and the plugs were virtually dry, just slightly smelly. I gradually worked my way up with more turns on the idle throttle screw up to about 3.5 turns in. The motor fires right on the starter and runs weakly for a second then dies. I tried turning in the air mix screw too as the plugs were still dry. When I gave it a rest I had a look down the primary venturi and noticed the throttle plate was open much more than I would have expected. I would estimate the throttle was open 10% or perhaps 3mm. Is that around normal? Whats a normal throttle opening in turns on the screw or in mm at idle? On Webers the adjustment is completely different and on FI engines I am used to ~2% throttle at idle with fine tuning in the idle valve...
Also I would very much appreciate a clear answer on where I should have the choke when doing this procedure. The truck and ambient temp is ~14 deg C or 55 deg F. Sometimes having the choke out 1/4 seems to help but when I go back to adjusting the idle throttle screw or mixture screw I lose my place again....
Thanks so much all for your great help!
I scanned back through your thread and didn't see mention of the idle solenoid.
Did you check it? Getting 12v?
Even if it clicks, it may still be suspect.
Here's a search to help:
I believe it is working. It clicks and it gets 12v same as the distributor.
Thanks for checking, if you have followup questions pls ask.
The screw dizzy is referring to can override your hard to reach idle speed screw. IOW it can crack primary butterfly too far open. The screw dizzy mentions is also called "hi-idle screw" or "choke idle screw"😅 Perhaps that screw needs backed out too.
pjohnson makes a good point. The solenoid can click and not fully retract. I had one do that. Pretty sure the FSM says solenoid should retract 5mm or so. Maybe pull it and check. Might as well hit the hole with carb cleaner and air if you pull solenoid for a test
The nozzle and or venturi is factory service manual lingo.
The choke will bump up your idle, and is adjusted on a different screw, so the idle speed adjustment for a hot motor will have no effect if the choke button on the dash is pulled (never mind what thebigredrocker just said).
This is turning into a marathon effort to simply get it to run! You won't have any hair left at this rate.
You'll get there soon. Sure you haven't got diesel in the tank?
Good luck!
Almost there!
So guys, is there a YES or NO answer whether of how the choke should be set during this initial start?
Choke all the way out. Even carbs without choke breakers will start engines for a little bit.
I'm uncertain about the secondary being fully closed. There are effectively two throttle plates on the '74 secondary. Maybe a good pic of that counterweight (round heavy disc on lever towards cab). Photos, in general, really help.
Hmm, in my experience, the linkage adjustments being discussed wouldn't cause it to not stay running. It would run like crap and you might have to hold the throttle open, but it would run.
I'm still thinking idle solenoid based on behavior. Or timing, but you seem to have that close enough or dead on. So, not that.
Hi, an thanks for staying with me here. The high-idle screw is backed way out, it doesnt touch the lever until the choke is ~75% out.
When you say "choke all the way out" do you mean out away from you as a driver or out all the way from the dash?
working off your observation that the ignition system is not the issue......wonder if/why the throttle plate is cracked 10% open, given idle speed screw and choke idle screw are backed out. Can you use your hand on the throttle linkage to close the primary throttle plate a skosh. Try starting remotely like that. Did you remove butterfly valves during the rebuild?
Did you use different valve lash specs due to the RV cam? Might not hurt make sure your cold valve adjustment is spot on.
Hopefully you are stocked up on beer🍻
I tinkered with valve lash on my two 2Fs about half a dozen times in a couple of years. The most recent time I did it, I found that being 180 degrees off on the camshaft (one crank rotation off) will be a subtle problem until you get to the #4 exhaust or intake (I forget). So, it made me rethink all of my previous assumptions, including how I set the distributor rotor to TDC on number 1. Basically, I was shocked at how close I came to making it totally wrong all the times before. The compression check would verify that the valves are closing if I was at all uncertain. I got to get this off my chest for the sake of the thread and those folks who read them to gain a mastery of trucks that don't do the thinking for them.
Being this deep into it, I'd also plug the vac advance line going to the distributor, and make sure that you have 7deg of static advance on the distributor. Too much advance made my 2F a difficult-to-start-motor. I personally made many timing mistakes by accidentally moving the advancer dial on the back of my Harbor Freight unit when picking the unit up or putting it down. The line on the flywheel is TDC, the ball is 7degrees advanced.
Plug the lines to the brake booster and PCV from the manifold to the .5F side cover. I'd consider using a screw on the hose, so the head of the screw insures that nothing accidentally gets sucked into the manifold. A carburetor can't work if you have a vac leak.
A choke button pulled out all the way out (from the dash board) should be good to get a correct start. You can also pull the button mostly out if you need to get more air into the engine and your choke breaker isn't working as it should. I'm assuming you have manifold vacuum routed to the choke breaker diaphragm.
More photos, please.
Thanks for the reply. I did accidently get it to run a couple weeks ago, so I dont think I have any mechanical issues. I did check the valves several times. I used the lash spec from Delta, where I got the cam. I forget what it was, but I am quite sure its set right as I marked each rocker with paint as I set and tightened each nut. I have done quite a few valve jobs on other cars and nothing seemed out of the ordinary.
Yes, last night I blocked off all the vacuum leakage weak points. PCV, brake booster, carb vacuum and distributor vacuum. I am desmogged so no "computer" or other leakage points.
I had the choke plate off for the rebuild but did not remove the lower throttle plates. Those stayed intact.
What's a choke breaker? I dont think I have that. This carb did run o this motor for years (until I meddled with it.)
The upper idle speed screw (green) is backed out all the way. The high idle screw is out of play until ~75% choke.
Can someone confirm a typical starting point for # turns or % or " or mm for the throttle plate when starting out? And 4 turns out on the air mixture as a starting point?
Off to the garage now to try again on fully charged batteries and dry plugs...will try a remote start to see if the primary jet is what is leaking out fuel.
AAAHHHHHHHHHH!!!!!! Another unsuccessful attempt. Tried with and without choke. 1 turn in on the idle screw up to 4 turns...air correction 1 up to 5 turns out. I feel like I tried every combination.
I checked the plugs when I started (dry) in the middle (dry) and at the end (dry but smell gassy.) The best I could get was no choke, 2 turns in on the throttle screw and 4 turns out on the air mix. The motor fires immediately but sputters out after a few seconds.
I did a remote start with video here. I dont see fuel coming out the venturi during crank/running. It looks like its just getting wet from the spitting back...Thanks again for staying with me!
My first strong impression from your video is your timing is off.
If it were mine, I would loosen the dizzy and crank it while turning the dizzy slightly to see if it will fire and run.
