Methodical first start process?
The choke breaker is the vacuum line attached diaphragm that lets the motor get air after you get sufficient cranking from vacuum.
The problem is the only screw that has a baseline setting is the idle mix screw. The idle speed screw is set to engine rpm, and the choke screws are specific to your year of carb. On these carbs too rich of and idle mix isn't going to not start, and with the choke set, you have a non-adjustable slow circuit that it will start on because the choke opens up the throttle some.
Maybe take the carb apart, and confirm the passage of the slow circuit? Did you confirm 7 degrees btdc timing?
Do what pjohnson says. It sounds like the timing is way way out . Twist that dizzy all over the place lol. [I mean 10-20 degrees each way]
I am guessing it's too advanced, so rotate clockwise [retard] first.
It's not THAT critical to have it exactly right to run. Hei systems should be timed after the engine is running coz of the cranking retard.
It may seem a bit nuts because you think you timed it spot on, BUT there is a possibility that you set the run timing to the hei's cranking pulse.
That could make it up to 10 degrees too advanced.
Nearly there.
Unlless you already tried this, then it's points dizzy or another carb because at this rate I will come back next year and this thread will still be going!
Edit just in case. If moving the dizzy in 1 direction makes it run or nearly run but you hit the block with the dizzy vac module [cant twist any further] you might be 1 tooth out on the dizzy gear.
Nearly there.
Winner winner chicken dinner! Well, that was one of at least 3 things I had going on...
So I have this new Innova timing light. Its super bright and has all kinds of features...but it was set for some funky correction. So what the timing light was showing at 9 BTDC while cranking was more like 29 BTDC! The distributor was actually 2 teeth advanced! I was so frustrated, and for some reason grabbed my old timing light to re-check and sure enough the timing wasnt even close! I retarded the distributor first one and then a second tooth and it fired right up!
After a few minutes getting it all warmed up (and fixing a loose coolant hose clamp) it started sputtering a died...no fuel in the float bowl...I had run out of gas...so trip to the gas station - started her right up. Then after a few minutes it started sputtering out and dying....WTF?
So after some head scratching and teaching the kids some new words...I checked voltage on the batteries...12.3...WTF? Charged them up and the truck started no problem...but the battery voltage still showed 13v gradually falling down to 12.6 when it started sputtering again...The alternator is not charging the batteries...back over to my alternator/gauge thread to continue that drama...come along! also here...>>>>Externally regulated new alternator/regulator/ammeter wiring
Thank you so very much bigredrocker, dizzy, pithicus, pjohnson, Whitey45, pb4ugo, Solace in Solitude, and anyone I missed.
