MC Pressure Check Valves (1 Viewer)
JJS
USA
Prior to pulling my MC and rebuilding it, the PC valve for my rear circuit was leaking. The MC was also leaking out of the rear, and down the booster. Was the pressure check valve open because the circuit had air in it, or is it just junk? I'm not exactly sure how they work. I forgot to order a replacement.
san pancho, ca
bsevans
Focus on the Journey
Southern Arizona
If you MC was leaking into your booster, don't be surprised when the booster fails. Brake fluid in the booster will eventually caused the seals to fail.
On a hill overlooking a lake in Idaho
Website
I'm talking about #5 on here. I don't think there's more than one direction in which they can be installed
http://www.sor.com/shared/image/014C.gif
You know, I think blowing into these from both ends should test them, though. Thanks.
#5 in the pic is a pressure valve for brake warning lights. Nothing to do with brake operation. If one of the masters fail, the light comes on at the dash.
JJS
USA
Thanks. I weren't sure what they did as I don't have brake warning lights.
I may as well add a new booster to the list as well. Thanks.
