I just had the point’s burn up in my Downey distributor. I left the ignition on for about an hour. Next ting I knew, there was smoke pouring out of the distributor. All the plastic parts of the point are melted. Why? The coil was so hot I burnt the heck out of my fingers just from touching the top of the coil.
I went and bought a new set of points and condenser for a 1970 1F. They don’t fit in the Downey distributor. The Downey points are held in by one screw and a cir clip which clips to a post fused to distributor. Clearly Downey uses a custom set of points or they are for a different year. I noted the Downey points have “made in the USA stamped on them.
Dose anyone out there know what the correct replacement points ar for the Downey racing distributor (19169?) Do you think I might have fried any other parts? I need to get a set ASAP as this is my daily driver. HELP!!!
