When you are talking 2 hopurs for the PHH, does that include draining the Rad, jacking ip the rig, taking off the tire, changing the hose, putting tire back on, filling the rad OR is it just for the hose part?
Mudshack said:Heater? What is that? I don't think mine has seen that setting in Houston.
dfmorse said:
landtank said:With this method you really don't need alot of room because you are only sliding the thickness of the hose wall between the two. Of course this is with standard hose, I can't say it will work with that super duper industrial space age stuff.
powderpig said:Any more on a good day I can have the job done in about 45 minutes. Lift truck(on rack)later robbie
landtank said:I can't beleive what a huge deal this hose change out has become lately. 8 hours and you need a special set of tools. That is a little rediculous. Using a regular set of tools it shouldn't take any more than an hour and a half and you don't need to remove or even loosen the lower bolt.
LabRat11 said:Land Tank .... I read that to mean that they spent 8 hours trying all the known methods. IE they changed the PHH more than once. The results of all the efforts is one recommendation.
So 4wd TOM- what are the final stats regarding the gear wrench PHH change out???
elmariachi said:Where are you coming in to that bracket with this wrench, from above, below or from the side??
landtank said:All that is needed for space between the pipe and nipple on the block is enough room to completely slide the hose onto the pipe so that the end of the hose is flush with the end of the pipe. That way you can swing the pipe back into position and push the hose off of the pipe onto the nipple. Just be sure that the clamps are on the hose as well first.
4WD Toyota Owner Magazine said:but we found it very difficult to get the leverage.
landtank said:There's your whole problem, there was 2 of you in the wheel well together. Actually suggesting people jump up on the engine to work on it is a little dangerous. People have damaged their radiators from getting up there never mind all the other more fragile stuff that could get damaged.
Next time you might try a bowl of wheaties for breakfast instead of a double whipped latte.![]()
landtank said:most people approach the task by accessing the hose from the driver's wheel well. Since you said "we couldn't get enough leverage" I was joking in that there was 2 of you in the wheel well.
So how in the hell were you trying to put that hose on the tube? If you weren't reaching in from the wheel well, where the hell were you coming in from?
