Max speed for locking the Center Diff?
Tuolumne/ Rancho Cordova, CA
I've been searching for over an hour and I couldn't find an answer to this one.
Last night after I installed a CDL switch into my new 80 I started wondering about when it would be safe to lock up the center diff? Is it safe to lock up while you're moving? If so what's the max speed you could safely do this at? In my FJ60 I would shift into 4 high (when the hubs were already locked) at speeds up to 35mph or so. I'm worried about what might happen if I ever let anyone drive my Cruiser and they decide to start playing with the buttons.
Off the topic- I love my new Cruiser! I've had it three weeks and I've already put 2,000 miles on it. I love having cruise control and being able to set it at 75mph on the freeway (I'm not sure if my FJ60 would even be able to make it to 75). So far I've had it on the beaches up around Eureka CA, I've driven Usal Rd up the Lost Coast, and this weekend I'm taking it down to Pismo! Better gas mileage, more power, better ride, and lockers- I haven't touched my FJ60 since I bought the 80. Now I just need to figure out a way to have my work pay for me to lift it and add protection...
This is only speculation, but because it's unlikely that the driveshafts would be spinning at significantly different speeds when you're moving (unless you're stuck) I don't see any reason you couldn't engage the center locker at 100 mph. I wouldn't do it on pavement though- that could get ugly. The fastest you would probably actually be going would be less than 40 MPH on a dirt road if you thought you might feel like engaging it.
None of that addresses someone unfamiliar with the rig pressing buttons for fun. Engaging the locker at any speed on dry pavement would not be desireable. If you're gonna lend it to people, you'll need to inform them about things like that. Maybe a warning sticker or something.
-Spike
I recall somewhere that the max suggested speed was somewhere around 40MPH, but have no documentation to back that up.
I recall that it was discussed long ago on the 80s COOL email group...but don't know if it's been covered here.
I've hit the switch around 25 to 30 MPH without problems (that I know of)...
-Spike
I don't plan on letting many people drive it- maybe my girl friend and my brother- and when I do let anyone drive it I'll let them know what not to touch. I just wanted to see if life as we know it would end if it happened.
My manual stated that it shouldn't be engaged unless your vehicle can no longer move under unlocked conditions. engaging CDL should only be done in loose ground to avoid breaking something from binding.
Is your manual referring to the center diff lock switch or engaging the CDL via the transfer case?
This was brought up last year about this time. At least one forum member regularly engaged the locker at 50+ while heading up to go skiing. IIRC, the manual says 35mph or lower.
I'm suprised the manual even mentions it since it wan't a factory option in the US after '92.
Turbo Turtle, your sig doesn't mention an 80, what year is/was it?
-Spike
The owners manual for my '93 has the same comment- but it is refering to locking the center diff by shifting into low range, not with an aftermarket CDL switch.
Any speed....
I've already driven my SC 80 a couple thousand miles with the center diff locked, on road or off road. Hours at a time, there is no reason not to.
You can lock the 80 at any speed, and just this past Feb I hit the diff lock starting at 60, and regularly exceeded 100 on the drive back to chicago with the SC at full charge on dry pavement.
Ideal brake force distribution (albiet no abs), better handling, more predictable handling, and better acceleration would be the benefits of locking the center. I can't see any reason not to, I've never thougt twice about doing it, even my track prepped quattros all run center diff locked.
HTH
Scott Justusson
OK, I'm gonna have to go on record as being in complete disagreement with Sumo on that.
First, drivetrain wear. With the CDL locked, both axles are forced to turn at the same overall speed. That's going to cause binding when turning- even if you can't feel it. The full drivelines will be fighting each other, from the u-joints through the diffs and on to the axles, birfs and drive flanges. Wear will be accelerated, that's a fact. 'Wear' in it's worst manifestation is 'breakage', but there are degrees in between.
Second, handling. On straight roads, there should be no ill effects. Take it into a turn, however, and disaster awaits. Normally the axles turn somewhat independantly, again allowing them to turn at their own speeds. Turning, the rear axle is going to want to turn slower, as it has less distance to travel. If the two axles are forced to turn at the same speed, something has to give. That something, if not catastrophic breakage of the drivetrain, will be the tires' traction with the road. That means that at the time you need traction- side-loading the suspension- one of your tires is already out of the equasion. If you should have to turn a bit tighter, perhaps tighter than you would normally at a certain speed- say you're avoiding a collision- you are already relying on only 3 tires to hold you to your turn. Hit the brakes or a piece of ice, and your downfall is imminent.
The arguement that 'nothing bad has happened yet' doesn't hold water for me. The forces involved must follow simple physics principles. You are adding stress and reducing traction with that practice. When you need the control the most is when it's going to fail you- in a turn, at speed, during a maneuver. Frankly, you seem like a smart person, I'm suprised you haven't seen this for yourself.
-Spike
Wear *can* be accelerated, it's not a fact Spike. My race prepped quattros don't have the option to unlock the center. What wears? Tires, that's it. Full race rubber with maximum traction driven 10/10ths. I don't break axles, neither does the quattro rally car I service, it also eats tires. They aren't fighting each other, they are just forced to turn at the same speed.
You have shock to the drivetrain, because you have awd. Locking axles only doesn't allow one axle to rotate faster than the other. I can think of better ways to parallel park, but the question was locker speed. If you lock it at all, your argument applies. Locking it at 100 won't change that, even if I was to agree with it.
BS Spike. Here's what happens. In a straight line with the center diff locked, f/R torque distribution follows weight distribution exactly, always. In a turn F/R torque distribution will favor the rear (based on turning radius and wheelbase) until it breaks loose, then it favors the front (from a turning radius forced torque argument to a traction argumet), which then results in understeer since a turning front wheel can't support 100% of engine torque under normal conditions. The speeds at which all this happens is based on wheelbase, cf, cog, tire load, slip angle, steering input and engine torque. Tires in awd inherently have more traction, even in turns, locked or not. I personally lock center diffs all the time because the understeer is predictable in a locked diff, spinup in an open diff isn't, especially in low cf conditions.
Unless a tire is lifted, it's not out of the equation. You can turn a bit tighter, nothing stops you from doing that. The understeer maybe greater, it depends on how much weight is at the rear wheel , that's not correct to make the jump to loss of control. Hit the brakes, you only have no abs, you haven't automatically lost control, that would depend on how much tire slip is present front and rear. Loss of control is a big jump. Spike, Audi raced with locked center diffs in awd for 20 years, in fact in many of the race cars they took at the center diff alltogether, cuz if you don't use it you lose the weight.
-Spike
Spike, come to Steamboat, or any quattro track event, I teach and practice and build car control with center diffs locked all the time. In fact, I lock my 80 center diff in Chicago traffic quite often. This is a long wheelbase vehicle compared to what I normally drive locked (99in quattro). My passion is teaching, advocating and understanding of awd performance. A big part of that is center diff locking and it's effects on chassis dynamics and car control. Locking center isn't just an offroad tool, it's a great way to educate yourself on the differences between awd open and locked center diffs. It's not inherently dangerous, it's a tractoin tool that has many advantages in everyday driving.
I can also show you Audi quattro owners manuals from lockers that specifically speak to the conditions under which locking diff has the advantage.
I have two passions Spike, turbos and awd. In awd, my passion is vehicle dynamics of it. You present arguments I hear all the time. I know that you will chew up a tire before you break a darn thing on a quattro, and the LC has drivegear massive in comparison, it's not a fact you will break a darn thing, that's an opinion without support. IMO/E.
A bit of audi trivia to leave you with. The first audi quattro released to the motoring press in 1982 was delivered with no center diff. They asked for feedback, and eventually added the dog clutch center diff. Parking the only complaint.
SJ
Sumo- Really? That's interesting stuff, Why do you lock the c-diff in traffic, what advantage does that provide?
A bit of trivia
If you drive with the CDL locked over a certain speed (45? 55?) for a certain distance (something like 500 feet IIRC) then the ABS will remain disabled after the CDL is unlocked until you shut down and restart again, where if you do not exceed this speed/distance the ABS will re-enable when the CDL is unlocked without having to shut down,
I have locked my CDL briefly (2 seconds or so) at 60 MPH on pavement to test his out, but it was a long straight away no turns during engage or wile it was locked
I would not drive through turns on a high traction surface with any of the lockers locked, for all the reasons Spike mentions, not even the CDL, on just packed earth loading in the driveline is noticeable with the CDL locked and increases a lot as each successive locker is locked,
A bit of trivia
That one caught me on an exit ramp for gas once, I couldn't figure out why the ABS didn't reset, even with the center diff lock light out. Restart all was good.
Let's be clear, I only advocate center locked for this discussion. Locking the other diffs is a whole nother issue.
I think if you guys only use center lockers for offroading, you are missing some of the best advantages to a center locker in everyday driving. I drive locked in Chicago at least a few times a week. I don't park with it.
I think a driveline wear argument is the funniest thing I've ever heard. In an open diff torque is always split 50/50, in a locked diff straight line driving, torque always goes to the wheel with the greatest amount of traction, torque follows weight distribution exactly. I'd almost argue you have less driveline wear, certainly always in a straight line, because you aren't forcing torque to a wheel with less traction.
Offset that with turning? The load on the driveline is progressive as the turn progresses. Where's all the extra wear and breakage exactly? I don't get it boys, I say the wear is equal or less with a center diff locked. It has the added benefit of never allowing one alxe to spin up, then shock load, since both axles can never rotate faster than the slower spinning one. I see this as mindset to the idea, not fact....
SJ
More open vs locked comparo
Steamboat Ice Track Feb 06
Open Diff
When I forgot to lock the center diff at this track on one of my runs, it became very apparent in the first turn. Go to brake, first mistake, the fronts started to ABS chatter, and the rears (select low) just didn't do a darn thing. Ok, let's try a turn and power up. Problem, with 50/50 torque distribution of the open diff, the truck just went sideways.
Locked Diff
Go to hit the brake. Regardless of F/R weight distribution, overrun braking transfers ideally F/R thru the driveshaft, resulting in a non lockup situation. Turn and power up. Since the front wheels are travlling faster than the rears, torque goes to the rear, and the back end starts to swing around, making the beginnings of a power drift very easy.
This is low cf conditions. There is no difference in hi cf conditions to the handling or behavior, it just changes the HP/cf ratio to tire slip.
This is just plain education to chassis and vehicle dynamics. A properly trained driver will have as much if not more control in a high HP: cf condition with the center diff locked. Boys, I have the track rented for second week of February again this year. I encourage anyone that 'thinks' they know awd to come play with the quattro boys with their vacuum air lockers.
Anyone can contact me offline for the details of steamboat. In the meantime, Spike and RT, I disagree with your summaries in 'wear' and 'control'. Try to spend some time with a locked center in everyday driving, it might change your thinking. You ain't gonna hurt the truck or anyone else.
SJ
Obviously, I'm not going to change your opinion on this online. If you can't figure out that having one axle held back by the other axle in turning is going to cause wear, then there's no way I can (or care to try) to explain it. If you're scrubbing tires, then you're binding. If you're binding, you're putting load on the drivetrain. Load equals wear. It's not that hard to figure out.
-Spike
-Spike
AWD has load and shock on the drivetrain because it's awd. The axles and gears on the 80 will tear a tire to shreds before it breaks. The VC will bind in a tight turn, so will a tight on throttle turn with an open diff. Wouldn't you WANT torque to go to the rear in a turn? Spike, get a ride in a torsen center quattro, have the driver turn the wheel full lock and acclerate. Dude it binds from the factory, that's not a breakage issue.
I find this goofy Spike. I've driven the integral to trans center diff quattros with 200k on them with the center locked for thousands of miles. I bind the crap out of the race cars, cuz I take the option of locking the center out of them. They don't break, and they bind, jump and make all the sounds with 99in wheelbase (the rally car is fully locked all the time F/C/R)
I look underneath the mammoth 80 in comparison, and laugh that that's the cause of breakage. High toque to a turned front wheel, I can see a birf popping, that's a cv joint issue that plagues just about every turning/drive wheel vehicle.
I think this is BS through and through. Push the button anytime you want. Even your warning to not do that on dry pavement isn't right. A dog clutch engagine diff doesn't care what speed you are at, it only lcoks when the driveshafts are spinning the same speed. Your warning should be don't try to do this in a turn, that's all.
Sorry dude, I just don't agree here. And thousands of documented race wins by audi and other production center locked awd's to back up my claims.
Don't make me come take your keys away man!:flipoff2:
SJ
OK.........I'm old skool, own an 80 but prefer the 40's 45's 60's for me......WTF would ya want to engage it at any speed over 15 mph.......I would treat it like front lock outs......if ya' think you are gonna need em.....lock 'em before getting in trouble.
Butch
