I kan spel Criuser. I did not edit the title before I submitted it and now I kan't fixer it.![]()
All your powers and skills and yet so powerless..........
Photo-less update.
Under-hood issues:
Valvecover gasket, spark plug tube seals, spark plugs, wires, cap, rotor, distributor o-ring, PCV valve, grommet, ventilation hoses, air intake hose, radiator hoses, all coolant hoses, thermostat, gasket, starter (replaced with a 93-only 2.2kw 28100-66050) alternator, belts, fan clutch, air filter and some snazzy paint for a few bits (Sarah wants it to have her "touch")....
Chassis:
OME 850J and 863J (supplied by Beno and I was told that they were originally Junk's springs) Trunk Monkey's 1.5 inch front spacers, 10mm rear packers. Christo's front and rear swaybar drops, caster bushings and adjustable rear panhard rod. OME "L" shocks, new OEM rear bump stops and OEM extended brake hoses (the rear and LH front are T100 pieces and the RH front is 2007 Tundra), OME steering stabilizer, locked-up viscus coupler removed from transfer case and tossed into the bushes off to the side of the carport.
On order, (5) Dunlop Radial Mud Rover 315/75/16 tires.
Body:
Remaininglol
flares removed and tossed into the bushes off to the side of the carport, My one-off Stout Equipment front bumper attached, POS roof rack to be removed and roof rust to be repaired, multiple lightbulbs replaced, running boards removed and tossed into the bushes off to the side of the carport.
On order, Metaltech sliders.
Interior:
Multiple dash lights replaced, front door speakers, added Husky Liners throughout, CB radio, center difflock switch and 7-pin mod (a personal favorite) , new driver's sun visor, fuse box cover, driver's door weatherstrip.
Hilarious. When I asked him the other day if he was doing anything to the truck, he said "Yes, I replaced the sun visor."
I can be when I'm up to my arse in aligators.......![]()
Photo-less update.
Chassis:
