Build Matubrembrem’s OJ60.06
curious if youve wired up a glow plug relay yet? Im confused with two wires and where the best spot to tap into for mine. Not sure where to go for "ignition" and "starter". Im assuming starter I just connect to the signal post for the starter but really unsure what wire for the ignition. Wiring is likely my least favorite and most confusing part of this swap for me.
I did however get my sensors/gauges from speedhut installed and functioning so im not completely inept at wirng! just dont look at all the loose wires down below, they are not important... lol
I did however get my sensors/gauges from speedhut installed and functioning so im not completely inept at wirng! just dont look at all the loose wires down below, they are not important... lolView attachment 4138572
I have not wired up my glow plug relay yet. I’m diving into wiring now. I have half of the original glow plug harness, it was cut off whenever the engine was pulled so I’ve got to extend that and re loom it. I was planning to wire it into the ignition switch with a timer to run in accessory mode but I’m not great with wiring so I’ll save that for later on. I’m going to wire in a switch to go where the choke knob was to a 100 amp relay and call it good.
I’m still thinking about how I want to hook up the tach. I’ll probably get the signal from the alternator.
