- Joined
- Apr 21, 2005
- Threads
- 115
- Messages
- 26,086
Thanks John. Would I be able to swap the steering shaft though? I mean will one from 71, 40 box go into 25 steering box?
For speedo this is interesting as I have got no linkage or drive gear on transfer box. On mine speedo cable is going all the way to rear axel. I hope I am not missing any link in between.
Looking at this https://www.sor.com/catproducts.sor?from=098&part.number=098-24&tabpage=TAB2 I'm guessing you could rebuild a early thru 67 model box with a 68 model thru 72 model shaft. The only difference SOR show is the spline count change 7/69.
Not sure I've even seen a speedo cable running to the rear axle on a FJ25. All mine go to the transfer case rear output. They are very long. They run across the top of the firewall to then down to the right frame rail then come in from the right side. All the FJ40s I have just go down the firewall then run back to the left side of the transfer case rear output.
