Manifold spring?
Matador98 said:
Hey guys that have experience with this one...
This weekend I finally replaced a badly leaking collector (donut) gasket, when fixed, made it much easier to realize that I have a leak coming from my rear elbow seam. It is actually a pretty bad leak, so Nomis, there is quite a bit of pressure on those seams.
My question is, my manifold seems to be tight everywhere else, as does my intake; can I unbold the EGR hardline from that piece of the manifold, unbolt it from the block, and then remove it without taking off the entire manifold? How is it to remove the elbows from the center section of the manifold. If they just slide out, if you can get it unbolted, it looks like it can be repaired without a full manifold removal and rebuild? Oh, and I'm talking about a 60 here, so the 40s and 55s may not have the EGR BS in their rigs. If so, ignore that part. This seems to be the best discussion in the forums regarding these elbows, so I'm asking here rather than start a new thread in the 60 series (just a note for the thread mongers!) So, can I take it off separately, in your experiences?
On my 78 I do not know if that is possible. There is not enough room to slide it back far enough to free it from the center section to remove. I had to take the entire assembly out and at that point I replaced the rings and springs on both ends.
Thanks bsevans, that is pretty much what I wanted to know. It looks from the picture in this post that I'd need about an inch of clearance to pull it out before the firewall. The 60 might just have enough room, I'll take a look at it. And worse case if I can't get it out, I have to pull the whole thing, so it might be worth the shot.
Thanks for helping a 60 guy out!
