man-a-fre upper adjustable control arms?
have had problems with driveshaft vibrations since i installed my lift.
I have a ome 4 in comp springs in front and 863j in rear. I have no armor or winch running light. Ended up installing castor plates and a dc front shaft but still have a slight vibration and speeds above 45mph. Im thinking it is my rear ds due to the change in pinion angle. I did change my u-joints out after installing the lift about a year ago. So maybe the upper adjustable arms might help? Or possibly a dc rear ds?
Did that a few weeks ago no difference still felt/heard the vibes. I noticed early on that the vibes would appear to be affected by the weight of the vehicle. For example fully loaded rear, full tank of gas, would almost completely eliminate the vibes.
I have not checked the drive shaft angles. I assume they are not to spec due to the 4 inch lift. That is why i was thinking about getting the adjustable upper arms for the rear. I have already corrected the front with castor plates and a dc drive shaft.
You could also try removing the rear shaft, and see if the vibes go away. In the rear with the four link suspension, the angles should stay correct (mirror each other) for the most part with a moderate lift. The front is a problem because of the radius arms; when the truck is lifted the angles in the u-joints change.
Yes, I would put the control arms on. Have the slee upper control arms but I can't imagine it being different from the ones M-A-F sell.
Every vehicle is different, especially with j springs, or in your case j springs in the rear. But with competition springs in the front I don't think it's that much different. Some yield 5" of lift and some don't, some need more caster and some don't, dc shafts, and some get vibes and some don't. Rear panhard?
At this point I think it would be trial and error, but if you get the complete kit I think you'll eliminate most of the vibes.
Just checked my rear ds i noticed alot of play in the fwd u-joint. I also noticed that the slip yoke has some slop when turning it. It also appears to have some play when pushed/pulled. Both methods used were with one hand on either side of the yoke. Is this the correct method? And if the yoke is bad what are my options?
I place my hand at the joint of the slip yoke on the outer section. I then try and move it up and down. I do this starting at the end of the tube and incrementally move down along it. What I've found is that you will find a sweet spot where the play is really pronounced. It should be tight all along the yoke.
The best solution I've found is to get a new shaft from Toyota. My shop was actually more expensive fixing the old shaft than the new one.
Landtank thanks for the help! when i said push/pull i meant up and down and there was some play. Your right it took some time to find the spot. What causes the yoke to fail? My truck is a 93 with 220,000 miles. I didn't have any issues until i put the lift on.
I suspect that the lack of proper greasing is what kills them. I've identified 4 now with problems. The problem is that once you install the lift the shaft is running at much different angles and the load on all the joints is greater. It just brings problems to the surface that has been there for a while.
The UPS man just dropped off my Man a Fre UCA's and they look great. So I took off one of my stock UCA's to replace it and put them side by side to check the difference. The Man a Fre UCA was about an inch longer than the stock bar. I think I had it screwed in all the way so I am wondering if I need to cut down the threads to get it to shorten up.
Because I need the UCA to be shorter than stock bar to bring the pinion angle back to spec.... Right? I'm not looking to put a DC on it yet.
