Man-A-Fre Headers
Eastern PA.
I just got a set of 6 into 1 headers from Man-a-fre and when I went to install them the notches for the manifold nuts is so large that the washers don't touch the header flange. With the intake inplace and all the nuts and washers on I can lift the header out. The holes are the same size as the washers... So what's wid dat? I don't know if this is a screw up or how it's suppose to be but I would need fender washers to mount this. I called Man-a-fre and they said send it back for a refund but I still need an exaust so any suggestions. My stock manifold was broken when my FJ40 was totaled.
Manufacture a large bolt with a spacer welded to it perhaps....you are a river of confidence as I just ordered a set of exhaust headers from Man-O-fraid today.
I used fender washers on my install and they seal with no leaks since install 3 months ago. I recommend studs/nuts instead of bolts and torque 10lbs over recommended (think mind are torqued to about ~40lbs).
Worked for me.
Man-o-fraid, thats funny. No need to worry, this is the first time I have heard of this problem.
You can probably try to do some larger washers, cut them about in half if they hit the intake side too much. The different year cruisers had slightly different thicknesses I believe, so sometimes we have to do some half washers to make it flush. The header does sound like it was machined a little off, so if you would like to exchange it, we wont have a problem with that. Let me know how it goes.
Worked for me.
I would also agree with this.Studs do seal up better. Also for the gasket, if you use the orignal Toyota from 68-75, it works better than the paper gasket. You can use the 68-75 for all cruisers with headers from 68-87.
Steve
I talked to Al and he said to try half washers. I ended up grinding down half of a larger washer so that one side of the washer was the size of the notched in the intake manafold and the other side was large enough to cover the header flange. I backed these up with the stock washers and torqued the whole thing down. I'm still a ways off from starting this beast so I'll let you know. I still have an original gasket that I got when I bought my last headers from Man-a-fre in 1976. They use to send you 2 to double up the gasket and I only used 1. The header looks the same as the one from 76 but the 76 notches are the same as the manifold.
If it makes you feel any better, I have the same header on my '70 FJ40. It has never leaked and it's been on there for over a year. I did however use the kevlar gasket from SOR. Don't know what difference that made, just didn't want to use a regular gasket with a header.
Chris
Toyo FJ40 said:
Steve
Sounds good, let me know how it turns out. Thanks for your response.
FWIW, I ended up using the FelPro gasket because the head leaked fluid and had to be be torn down after the 1st rebuild. Lots of Permatex Red on both sides, stud/nut combo, and plenty of torque and that baby runs/sounds great.
Man-o-waytofartodrive headers are a thumbs-up for me.
Jeremy
Will try it when it gets here, thanks for the reassurance Steve-O. I will let you know how it lines up as I am waiting for it to arrive. Back to putting the rocker assembly on for now.
Without seeing it, I would just have to guess that the header was prolly notched to clear the larger studs on a 2F engine, and that you have an F.
There are other washers inbetween the stock size and the fender washers that are the correct diameter to fit in the intake notches and 'capture' the header. I make sure I keep a good supply of them around for in house installs. :)
This is for MILETWO:
My son just bought a 72 FJ 40 with what appears to be a man-a fre 6 into one header (btw, did or does anyone else make them?). Engine runs very rough and we cannot adjust carb. Searched for vacuum leaks and found big one around #5&#6 intake and around #6 exhaust.
I picked up a toyota manifold gasket and we plan to drop the manifolds this weekend and install the new gasket.
Question is: you put RTV on both sides of gasket. I can see where that would take care of minor warping, so we plan on doing the same thing. I'm only concerned because Permatex says don't use the stuff on manifolds. Is that just cover-your-ass stuff from the manufacturer? Sounds like you made it work. Any down side or trick to it?
Thanks.
Don't know of a down side... or trick other than put it on THICK! Anything that squeezes out the outside wipe off. Whatever squeezes into the inside, the fire will take care of :-). If I remember correctly, it was the next day after the manifold install before I got the carburetor put back on, so the full 24hours of sitting/curing may have also helped. If you have the time to not drive it, I'd recommend pull the carb off the manifold and install the intake/exhaust with a fresh gasket, lots of RTV red and let it set a couple of days while you rebuild the carb. Then reinstall and tune the carb/timing and you should solve the rough running. You can find lots of info on this board for tuning your carb and timing but feel free to look me up if you need more info.
BTW - where are you located? I'm in SoCal and if you're local I'd be happy to come by and check it out for ya.
Regards,
Jeremy
I think the key to any header installation is to use an OEM gasket or the FelPro and retorque, retorque, retorque. I did mine five or six times. There was big change at the first two intervals then it was less and less, until no change.
If you wait until you have a problem, the gasket will most likely be Fubar'd ala Morton Thiokol. Once the fire breaches the gasket its a re-do.
I'm also partial to the headers that have the same flange thickness as the intake.
GL
Ed
I used no "Red Stuff", but the guy before me did, and that's why I didn't.
Damm this thing is heavy! It did get here quick, the finish welds could have been alot nicer, but you get what you pay for at $170. I got the chrome to slow the rust. It seems to line up ok and I fabbed some enlarged bolts to work the spacing, not a big problem.
I was going to get the chome but the their web page said chome paint... So I went for the black paint :doh:
