Man-a-fre disc brake conversion report
Cedar Rapids
Just finished the MAf front disc brake conversion. I read a ton of threads on the topic prior. I thought I'd post my results for anyone who may care to read this down the line.
I have a 71. Did the front only.
Night 1 I mounted the proportioning valve on the rear tubing as recommended by everyone on here. Hadn't done tube flaring prior. Wasn't that bad at all. The fittings worked without leaks on the first try. The valve was on the line so firmly I decided not to try to mount it to the frame. I think it will be more than fine as it is. as far as problems, I had some trouble getting the large nut off the master cylinder to get the spring out but with the aid of some penetrating oil and a large pipe I got it off without breaking the master cylinder in half:)
On day 2 I started the rest of the process. It was as simple as they say. Disassemble old hub and remove the drum. Disconnect old brake line. Bolt on the bracket. No grinding required. Fit easily.
Reassembled the hub, slid on the rotor, mounted the caliper as recommended, Had to be a little careful with the hex screw as it lies close to the steering arm once mounted but it was doable. I reconnected the brake line with the braided hose MAF provided.
The only issue I had was with the wilwood bleed screws. I assumed that they bled like most other bleeding valves, by loosening the nut that goes into the body of the caliper. I couldn't initially figure out why no fluid was coming out the nipple. Until I figured out that the nipple screw in the brass fitting was what needed turned to bleed. Ughhh. Lost an hour and a trip to the hardware store for more fluid before I figured it out.
As far as the change to the pig.......They work as advertised. Converting to disc makes the braking process MUCH easier than before. I took the opportunity to adjust the rear drums at the same time and then spent a few minutes on a road alone adjusting the proportioning valve to keep from locking up the rears early.
Thanks for all the help and all the old threads on here that got me through this process. I must say my wife was certain when she saw all the parts laying on the garage floor that I would never drive it again in one piece. I havent had a truck I could work on since the 80's. Before I met her. Guess I made a believer out of her:)
Very glad I did this in the end though it took a day and a half to do it without help.
I should have taken some in the process but I didn't think of it at the time. Just trying to get it done.
I'll post some after pics though as soon as I can.
You can bet that the next stuff I do I will take some as I go.
Pics of the proportioning valve and the location, detailed as it will help me install it on my truck. I also just did the front brakes and the pedal gets stuck after two braking attempts (faulty booster probably which is spec for drums)
Here's my prop valve installation, removed old OEM prop valve and installed new in same location.
full
Here are my pics. I dont have any yet of the disc with the wheels off. I may take some tomorrow as I want to bleed the brakes on more time as I am not sure I have them tuned exactly as the brake pedal the first few uses after I start the car are alot harder than any othe time. It seems to operate better ince I have used them a time or two each drive. Other ideas?
Thanks for posting this been contemplating this conversion also. I didnt realize the prop valve was necessary. Have you driven on the freeway yet? Just curious, i saw a note that it is not recommended for highway road use, is this true?
Yeah it's necessary. In fact I thought I had mine adjusted correctly. I had done some trial emergency braking just after install.
Last night however I had to slam on the brakes to avoid hitting a deer. The rears locked up early. This was real life type braking which inevidently I didn't recreate properly when setting it up. When the rears locked up I almost spun out losing control. Needless to say, immediately after I spent a half hour dailing it in again. The whole event scared the crap outta me.
To explain, the prop valve does absolutely nothing under normal daily brake pressures. Stop and go etc. it lets these pressures by unregulated. It only kicks in and regulates the pressure under extreme braking. Like slamming on the brakes. Drum brakes lock up under high pressure situations much easier than disc. So this valve lowers the pressure in these settings to keep from locking up the rear brakes, and losing control, before front brakes do. Trust me. It works and is needed.
adjusting the proportioning valve is best done on a dirt road
How do you set it up, Its my first time for these kind of upgrades.
I set the caliper up in the position MAF recommended.
But no, I had no trouble bleeding it in that position at all. I considered taking off one mounting bolt and rotating the caliper up to bleed but it wasn't necessary. I had to bleed all 4 ports on each side instead of just 2 but once I was done with it all done correctly, I drove it and it brakes phenomenally. Pedal firm, only need to use light pressure to stop unlike the hard brake I had to apply with 4 drums.
Lastly, be sure you bleed out the master cylinder with 2 brake lines porting out into the fill chambers prior. Failure to do that the first time had me bleeding the system twice. That was why I was having braking issues when I first drove it that I talked about above. That's all solved now.
For disc brakes, the best setup is dual diaphragm booster with brake proportioning valve. Based on your photo, it looks like you can use a new master cylinder as well.
img_5937-jpg.1107180
brake hard on a surface where you can slide (such as a dirt road) - have someone observe whether front or rear locks first - adjust proportioning valve until front locks first
How do you manage to get the correct brake bias ?
Well as I said it took me a couple of times at least. All I was doing is heading out to a poorly traveled paved road and slamming on the brakes. If the rear wheels locked up (watched them out my side window rather than having an observer) I would stop and turn the dial on the prop valve then repeat the process. I did this until the hard braking didnt result in the rears locking before the front.
I may take the above suggestion from DSRTRDR and try again on a gravel road to be sure.
How does the dual diaphragm setup differ from what I have? I can see the visual differences but functionally?
Dual diaphragm boosters produce more power, which is needed by disc brakes. When Toyota went to front discs in '76, they switched to dual diaphragm.
From what I'm hearing, single diaphragm still works for the front disc / rear drums set up; however, when you go to disc brakes front and back, I think you are living on the edge there.
When you make brake mods, you are acting as your own engineer. Make sure you engineer it right so that you don't put your safety at risk. The way Toyota engineers designed such a system is dual diaphragm brake booster + brake proportioning valve. I wouldn't skimp on anything, as you can't argue with physics.
