Got tired of having 4 keys (one for ignition, one for door locks, one for fuel door, one for ambo door). So I chose the ignition key as my primary and yanked the other locks to see about pulling them apart and make them do my bidding.
Get the lock out, remove the E-clip and spring off the back then softly chuck it up in the vice and use a flat head to start prying the ring up, evenly, all the way around:
Hold it together, remove from vice and remove outer ring, inner key slot plate and hinged door (remove hinge door spring and set aside before it gets lost, trust me). Then carefully slide the core out the front of the lock with the slots to the side so they dont fall out. Now insert the key you want to use and see which tumblers stick up, or down, past the core:
For reference, here is all the internals, minus the tumbler springs I left in the core:
Anyway, pull those offending tumblers out the top, being careful not to lose the spring. You can now switch those tumblers around to see if you can get flush across the top, or as close to it as possible. You shouldnt have any hanging out the bottom when the key is inserted, if you do then you discard that tumbler and its spring. If you still have one or two sticking out the top then remove them and file them down till all are smooth across the top when the key is inserted.
Slide the core back in to test fit and ensure it rotates smoothly. If so, remove it, use a thin coat of lube, reinsert it and remove key. Reinstall the door spring, door, and inner keyway plate. From there I slipped the outter ring over a pen and used the pen to hold those pieces in place while installing that outer ring.
