Make both dome lights turn on at same time?
Portland, Oregon
Website
localcred.com
Has anyone ever tried to mod the dome lights so both would turn on if any door was open and they were both switched to the "Door" position? Maybe just run an extra wire between the two lights above the liner?
This seems like it would be a pretty nice mod. Even better if it included a third rear light like some people have done.
It seems the wiring for a third rear light is already installed in some cruisers. Also, your idea of just a wire in between the two lights should be fine, just becarefull of any diodes used in the system to operate for example the 'door open' dash light as I am unsure if they use the same switch. The only real reason I can see for not doing it is the possible chance of a flat battery if both are left on for example overnight. Of course the use of LED's would sort that issue out as the current draw is so low.
regards
Dave
Yep did it to mine, just ran a wire between the map,front and rear lights. Now when I open the door or turn on the "map light" above the mirror all the lights will come on. This will kill your battery pretty quickly with all 7 interior lights on at the same time when a door is not closed all the way.
....which is why I moved the interior lights to the aux. battery. Going to George's LEDs helps greatly as well. But yeah I connected both lights as well and will be adding the third one of there years :rolleyes:
You should be able to connect the wires, in the driver's footwell, area, I just tied into both for the door trigger wires for my alarm install. In fact I did connect them both to one wire in the alarm harness, but I used diodes to isolate them from each other. Only "downside" I can see, is that the retained power for the headlights would turn off when any door is opened, rather than just the drivers door. Though I can't find a reason that it would matter to anyone... ;)
Great ideas.
I would not have done this if I did not have a dual battery setup. I can just imagine killing my battery out in the middle of nowhere just because someone did not close the door all the way the morning we left to go fishing. Actualy I dont have to imagine this because it has happened but all I had to do was switch to the other battery and off we went. Granted my battery at the time was not the best but 8 hours was all it took to kill it.
Has anyone ever tried to mod the dome lights so both would turn on if any door was open and they were both switched to the "Door" position?......
You should have got a '94 - that's how mine works, stock. Of course I don't have the fancy door lights, which doesn't bother me.
......Even better if it included a third rear light like some people have done.
I want to mod mine by putting in a cargo(3rd) light that is independant of the front domes and is triggered only by the rear hatch. I don't see why you'd need that light on unless you were opening hatch. Plus I don't think it's necessary to trigger front domes when you open rear hatch. YMMV
I think having the the front map light up the front seat area and connecting it to the second row light is very practical and worth the mod. Toyota missed the mark on this one by a long shot - why in the hell do they want to illuminate the second row when the first row doors are open is beyond me!
