main venturi dripping fuel
Boonsboro, Maryland
Engine is no longer dieseling. That was the fuel cut off sticking. Cuts off fine now, but I still have gas leaking out of the butterly shafts onto the manifold when it is shut off. I pulled the airbox just as I shut it off and there was gas dripping out of the main nozzle for a bit collecting on the butterfly valve.
Why would it do this?
I have to check the float level again seemed a tad over the center dot now for some reason, And I just checked it again an hour later and it is down to even with the hole going to the accelertor pump which is just under the dot. Is that in direct relation to float level and going to drain until it gets to that level unless the float is adjusted correctly?
Will check it again in the morning and see if it goes any further, the top is off of the carb so i dont know if it is the siphoning thing I have seen on here. or if it would still siphon with the top off.
It is running fine. but there just seems to be too much fuel in there.
Pinhead I know you have this stuff down. :cool: exactly which ones are the air vents that could get clogged. and is it the top cover that I need to look at. Thinking they are the pin size holes that are in the gasket just beside the bowl?
For the gas to be dripping off of the butterfly shafts, first it would have to get there by dripping out of the emulsifiers. Considering the emulsifiers siphon the gas out of the fuel bowl by means of vacuum, in order for them to draw when the truck is off, there would have to be a positive pressure building up in the fuel bowl.
I'm having trouble understanding why fuel would drip out of the primary nozzle with the engine off too. Seems to me that the nozzle is too high to siphon and it is hard to imagine how the fuel bowl could develop a positive pressure. It can siphon out of the transition slot, which is just above the throttle plate.
There is an air hole at the top of the emulsifier tube, which is an integral part of the nozzle. You could remove the two screws that hold the nozzle, remove it and see if all the holes are open.
Sometimes it is easier to just rebuild the whole thing rather than spend the time to figure out what is going on.
I did rebuild the carb. standard kit. It wasnt in that bad of shape. Like I said it is running fine. I am just conserned with fuel on a hot manifold.
It only dripped for a minute right after I pulled the airbox. It had stopped after a minute. Went inside and typed this up. Came back out an hour later and the fuel bowl level had dropped from just above the dot to even with the hole that goes to the accelerator pump. Gas had already evaporated from on the outside of the carb.
But that dripping gas from the nozzle area (cant really tell if it is coming right out of the hole or running on the underside to the hole and dripping down). Was definetly dripping with engine off.
When the truck was started the fuel level was correct. It almost looked like when I hit the gas the float would rise above the sight glass (couldnt see gas level anymore). after a second at idle it came back down to just above center.
I will be taking the nozzle off and checking it clean it, float level and air vents as well tonight and see what happens.
Maybe just the residual fuel around the emulsion tube is dripping? In any event, there is an air hole for the emulsion tube that is there to mix the fuel with air befoe it hets the nozzle and this air vent would prevent any dripping from the nozzle when you turn the engine off. The air jets are critical for getting the proper mixture too.
When you rebuilt it, did you dip clean the parts and did you blow out all of the tiny holes to make sure that they were free and clear?
Yep diped them and blew everything out. I am a pretty maticulous person so I did what I could. first carb as well though. so ???? I will be going through the top cover and emulsion tubes again in any event.
think anything with fuel level has anything to do with it??
I doubt it, unless the fuel level is all the way at the top of the bowl. The nozzle should never see liquid fuel; just atomized fuel, so there should be nothing to drip. The fact that you see gas dripping there indicates that the fuel is not getting atomized. Those little tiny holes are hard to see unless you know what to look for. Usually they are a little metal insert pressed into the aluminum casting.
I am having the same problem with my quadrajet on the 350. now I am planning on getting the whole thing rebuilt
Metering well plugs on bottom of qjets notorious for leaking and causing all kinds of flooding problems. Rebuild kits wont fix this problem. But aftermarket repair kits are avalible for just this problem.
it isnt overly hot, just tried seeing what was going on again. start it up. no choke (warm here). idled fine. everything seemed good. float is in the center. then the fuel bowl would slowly start to rise. all the way up out of the sight glass. then it starts to drip a little. I gave it some gas. (accelerator pedal).
look and it is dripping out of BOTH venturi's. I am even wondering if it is gas that is getting all the way up to the gasket and dripping in from there. but it is clearly coming from the center of the nozzle. All of this within. 2 minutes. Not even time to warm up.
I took the top of again. The fuel level is 3/4 up sight glass. gasket is wet. and it is not dripping anymore. ????????? Stops dripping 30 seconds or so after it is shut off. Like I said I rebuilt the carb with everything the kit comes with. New needle and stuff. Keep reading the carb info tech and trying to narrow it down to what circuits are working correctly. out of 6. acclerator seems to work like it should. Choke not even used. dont know what could be wrong with needle valve. like why would gas keep rising in the bowl, the needle should stop that. but it is new and put in correctly.
Float level correct. dont know much about the other circuits as far as what would be wrong. like I said it runs good. (until the fuel starts to dump)
It will definitely drip if the fuel level is above the level of the nozzle, so if the fuel level is higher than the dot, this could account for it.
Could be a bad or dirty needle valve and or seat or it could be a bad float. Fix the fuel level problem first and then see if the drip problem goes away.
Went through everything once again. Adjusted the float perfectly. Checked needle valve and seat. Was doing good, fine tuning some stuff for 20 minutes or so as it was running. Then of coarse it did it again. Didnt drip too bad or for too long but the bowl filled up again. It is a plastic float, it is good. Needle and spring are new.
What can I do to the needle and seat to figure this out. I think I will put the old one back in, don't have the old spring though. Are they really that finicky to let fuel in that easily? Dont understand.
Will check that out. Been so long since I rebuilt the carb. I hope I put it in. :D
Like I said it does good for a bit then just fills up. So that is an idea. It would take alot to clog a needle up and not allow it to close wouldnt it. screen is in place and all. Just wondering if little granuals would do that.
Also how often does the valve open and close? If the level is always in the center, does it do just little quick open and close actions. to only vary the level a mm or two. Just trying to visualize the operation. Thanks for all your help Pinhead. Would be lost with out some pros
I have an odd problem where the float sticks down every so often
and the gas must get dumped into the carb because the engine
stumbles badly and smokes like crazy. It goes away in about 30
seconds. Can you watch the gas level at different engine speeds?
Does the level go up and down?
Will know more tonight when I fire it up and see if I fixed it.
The gasket above the seat looked fine. Replaced it with a spare anyway. The one thing that I did notice is that the needle that came in the rebuild kit has a slightly different profile than the old one. Not sure if that could be an issue or not. I put the old needle in just to try it out. I am also wondering if the needle dosent push straight up that it wouldnt seal all the way. There is that little bit of play to it side to side if you know what I mean. and the fact that the float pushes at an arc. but the needle should seat right still.
I noticed some granuals in the fuel filter so I replaced that as well. Must have still been flushing out the lines from sitting so long. Will see what happens.
The gas level was good for a while I had only noticed it fill after I was giving it some gas to troubleshoot an off idle bog. Did the carb spray in the idle solenoid hole as well last night and blew through it again and will see how she goes to fix that.
Seems to be working fine now. I think the swapping of the needle did it. Or a combination of changing the fuel filter again. Either way no more fill up.
On a side note. Do Crusiers have a "slight" bog off idle. It is a lot better than before, but still has that second of catching up. I rebuilt the carb again so I know all passages are clean and working.
Took it for a spin the other night for the first time in probably 10 years. got up and went pretty good.
Now I just need more brake work.
Most likely you aren't getting enough fuel through the "transition" or "off idle" slot, which is immediately above the primary throttle plate, so that it sees vacuum as soon as the throttle is cracked. This is part of the idle circuit, so the idle solenoid and slow jet are also potential culprits.
