Main Engine Harness install
Hope everyone had a nice TG!
I will be installing a new main engine wiring harness today. (part # 82121-60343)
I have been chasing a misfire for a while and my current harness was not only brittle but pretty rough in some spots near EGR and injector clips etc.
I have read a few threads where people mention some tips, but does anyone now if there is any documentation or instructions out there? I know its not rocket science, just like to be informed. Any info is much appreciated.
Do you have replacement gaskets for the throttle body and intake plenum?
As with most things just go slow and be gentle, especially when dealing with the fuel injectors and sensors. That plastic gets brittle after 20 years of cooking in the engine bay.
Yes i have gaskets.
Should have mentioned, I also plan on adding extra heat tape stuff near EGR.
Do you need to take off Upper Intake plenum? Obviously throttle body is coming off, but was not certain if intake needed to.
It made it much easier to get to the injectors and to feed the wiring through down to the transmission. With small hands you might be able to reach inside and attach them.
When I did my HG I could never ever reach the plug down by the DS bell housing. Nor could I get the harness back over the transmission from the O2 sensor connections... unless of course I wanted to disconnect the 'U' joints and drop the transmission mount for clearance ... so I opted to leave the intake manifold in place. R&R the 'main wire' will be "lots of fun" ... good luck.
I've said it before - cutting the lower intake to make it removable without pulling the harness through is the way to go.
I had the same issue as @AJP - so I spaced the lower intake on the studs using some 1/4" plywood shims, and a fresh blade on a sawzall. I had plywood between the head to protect the head gasket surface for the intake gasket.
Once off, round the cuts & smooth it all down nice to avoid any cut/wear issues on the harness.
The metal between the runners isn't critical in that spot - you have mounts on each side of the missing metal, and the overall rigidity isn't at risk.
Been running since 2002-03 like this on the black 80 & the bonus is I could pull the intake for whatever reason without mandatory harness pull - a project near to itself.
I've never regretted it anyhow. If I was ever building a new 1FZ for whatever reason I'd do this to the lower intake I was going to run.
I installed a new harness when I did my HG last year so my plenum was off. The wire that routes over the trans to the O2 sensor can be routed under the bell housing and clamped to oil pan bolts for a tidy installation that has caused me no issues.
This sounds like a good plan considering this seems to be the biggest problem most folks encounter.
the routing of the wire over the tranny is a PITA unless you unbolt the tranny cross member and drop the rear down a little to get the access you need. I then route it properly back over the top before bolting the cross member back in place. Not really that big a deal.
I will be tackling this tomorrow. Hopefully its not too much of a PITA. I have never dropped the tranny before so it would be a first.
Are you referring to this...
No the cross member that goes under the tranny and extends from frame rail to frame rail. It has 4 bolts at either end. I place my floor jack under the cross member, take out the bolts and then drop the jack 4 or so inches.
Gotcha...so the cross member in that picture but the 4 bolts on far left and right connecting it to chassis? Or not that at all...sorry this bit is new to me
I got the old harness out today. Honestly the hardest clips to undo are the 2 big white ones wrapped in foam near the fire wall directly underneath cylinder 6 lower intake. Had to take front driver side wheel off to get access similar to the way you change a starter motor.
I will being install tomorrow on new harness. I suppose if you are gentle you can get the harness through the small whole between engine block and fuel rail...debating taking that off again though.
When I did this years ago, I cut the manifold:
When reinstalling, I did not run the harness through the intake runner like Toyota has it set-up. I unwrapped a bit of the harness and routed it around the manifold.
HTH.
Yea thats interesting and would make removal and install easier for sure.
And by routed around manifold I assume you went towards fire wall?
Yes, I unwrapped the factory tape at the intersection where one half goes through the intake runner to the injectors and brought it up and around vs. through the runner. Then the section that connects to the knock sensors and the other sensors were brought down underneath the lower manifold section.
I might have a picture of my routing that I can post in the AM.
Regards.
-onur
