Thought I was going crazy there for a sec, or have a heavily modified rigthat picture is not of an 80 under carriage. Best to go out and look under your truck. it should be clear then.
Ha that was my bad...tried to grab a photo from online to ask a question. failThought I was going crazy there for a sec, or have a heavily modified rig
That makes sense to me. Yea I am curious to see a picture. Seems like a better plan than the OEM routing.Yes, I unwrapped the factory tape at the intersection where one half goes through the intake runner to the injectors and brought it up and around vs. through the runner. Then the section that connects to the knock sensors and the other sensors were brought down underneath the lower manifold section.
I might have a picture of my routing that I can post in the AM.
Regards.
-onur
If you still can, tie heavy string or fishing line onto the tranny end of those connections and keep them easy to reach. I chased a speedo problem for weeks because one was short of completely plugged in by less than 1/8"I got the old harness out today. Honestly the hardest clips to undo are the 2 big white ones wrapped in foam near the fire wall directly underneath cylinder 6 lower intake. Had to take front driver side wheel off to get access similar to the way you change a starter motor.
I will being install tomorrow on new harness. I suppose if you are gentle you can get the harness through the small whole between engine block and fuel rail...debating taking that off again though.
