This back and forth stuff is not only fun but we all can learn a lot about build and design issues. I'm glad responses keep coming. OK, there are a few things to respond to:
***If someone feels that Toyota implemented the IFS based on off-road performance (not gravel roads/washboard but actually off-roading as it manifests itself here in the US) please elaborate***
YIKES....definately not. It obviously was for on-road AND off-road "ride and handling" improvements. The 100 handles better in both situations. Some of these improvements are also due to 9 crossmembers in the 100 vs 5 in the 80. Structurely the 100 is far more tighter and stronger (technology??) As for off-road "off-roading", of course the IFS does not equal a live axle, however the difference are not as great as many (who have never seen 100's in the bad stuff) state. The buddies in my Club dogged the IFS when I first pulled up for a run. Now, they're silent as the 100 has proven itself greatly. IFS has never stopped this truck even on 4-rated runs. It's size has been the only limiting factor so far.
***the front differential - lower it ???***
Yes, mine is lowered thanks to Doron's smarts. It allowed for another inch lift, OK CV angles (80K HARD miles on them), and 35's to run on the 100.
***get up to ~13" front travel***
Unless you want to run those worst of trails 4+, you don't need 13-inches front travel. The typical highly modified 80 doesn't have that either. Buying a 100 to run those trail types is silly any way. IT'S TOO BIG!
***John, come on - 7.5" front travel almost as much as an 80??***
This is what I've been told in the past though I do not remember the exact 80 spec? I believe it was 9-10 inches WITH L-series shocks??? Anybody measured it?
***the rear springs on both are the same - OME 863 springs. So I don't see why they wouldn't be very similar in flex capabilities.***
Not so. I have 865 springs and the travel is limited by the shocks, not the springs. I suppose the shocks may travel farther than the 80-shocks....though the 80 L-shocks have 1-inche more travel than the 100's.
***my 80 will eat your 100 and crap GX470's. But it is not stock***
You're right clownmidget. In the really bad stuff, your, AND MY 80 will eat my 100. I've never said the opposite. What I do say is that you can grab the off-road books, select 92% of the trails in them and I can run them and without incident despite IFS, despite 6-inches lift, and I can do it in far more comfort and in some situations have even more control (like when a rear locker isn't enough....I can run a locked rear and traction-controlled front giving me full turning capability while you risk breakage being locked up front. Of course if need still more I can lock the front too, though the traction control on the 100 is amazing and rarely do I need a locked front.
***Or stay closer and do Chiva Falls***
It's not final, but I should be running Chiva in November as a AZLCA Club leader (in the 100). You're more than welcome.
***Why not just get a 105 front end here and replace the 100 front?***
A 105 option here is a dream for many. Personally, I would NEVER give up my IFS on the 100. It does the job 93%of the time. For the 7% extreme runs I can live with the poopy ride and handling of the solid axle and count on it to get me through. That's why I have an 80.
If I could only afford only ONE Cruiser, I'd be lost at what I'd take? Because we off-road so often I think it'd be a 100. There's too large a difference in power, driveability, and comfort. Factor in slippery conditions and you're even more happier with it. Since I could do almost all the trails out there.....ya, I think it still be a 100 and not a 105 or an 80. Thank God many of us can afford 2 Cruisers. That makes these "wars" more fun! Build 'em for different uses.
