Lx450 Sub-woofer Replacement
Pleasant Grove, Utah
I replaced my stock door speakers yesterday with Eclipse 6.5 inch 3 ways, disconnected the in dash speakers and removed the stock Sub.. The stereo sounds a lot better, but I wanted to see if I could find a replacement Sub that would fit in the stock location and work with the stock amp...
Well my search has ended!! I found this 4" woofer with an aluminum cone, wide range of frequency response and is 4 ohms!! for under $12. Here is a link to the speaker
http://www.mcminone.com/product.asp?catalog_name=MCMProducts&product_id=55-1854
I placed an order today and i will update when i get it..
later
Bret
PS. i know that it wont be great but it may sound good??
FYI, Stock LX450 subwoofer is a 4" Pioneer @ 2ohms. You won't get as much output from the 4ohm replacement unless it has a much higher sensitivity than the stock sub.
I would luv' to read your opinions on it but I think Long Duck Dong's Sub enclosure is the best option out there. Although quite a bit more pricey than what you are looking at. I can't believe it's a $10 speaker you are putting in there.
I have done the same as you, Eclipse in the doors, dash & sub disconnected. I would disconnect the roof tweeters but I can't get the damn grills off. Already cracked one and still can't get it out.
I have checked all the wholesale speaker suppliers and the $12 speaker is one of the more expensive component speakers out there in the 4" size. They start making nice stuff at 6.5".. I will be putting in a new DVD head unit and a real Sub in the near future, but for now this looked like fun..
later
Bret
You have to drop the headliner. IIRC there are small nuts holding them in place.
later
Bret
I wouldn´t waste a cent replacing the stock sub. For God sake is a open enclosure and the stock sub amp is a bad joke.
This is the worst OEM sub ever designed and it´s a shame from Toyota R&D engineers:flipoff2:
The enclosure on the LX450 is a sealed ABS box. And I can't leave anything alone, I lay awake in bed thinking up things to do... so if spending $12 for a speaker kills the "what can I do next bug" even for a little while, it is money well spent..
later
Bret:flipoff2:
I have those same dreams...... i understand... glad to see i'm not the only one... thank you,,,...... lol
Thanks a bunch. No wonder it cracked!!!!! :rolleyes: Good thing is I let go once I heard the crack and you can hardly tell that it's jacked. :grinpimp: Never read anything about those small nuts in any stereo write-up. He He I said "small nuts".
Well I have a 94' cargo light to install anyway so the headliner must come down. Not looking forward to this. Don't want to crack that. :confused:
