I’m really tempted to just through in some LC springs in especially since I did the sensor lift. I was thinking it would also be great if the AHC system ever failed.
Wow. Thread bump du jour.
As Grinchy says, terrain tamer makes progressive, uprated springs for a 100 series AHC that are stiffer than normal 200 AHC springs but not as stiff as stock 200 springs. I installed them just about 2 months ago and they have been great so far. The ride is just as good (my wife thinks it’s better now), and the AHC goes much faster into H. On the other hand, sometimes it will not go into AHC low mode. It does, however, adjust normally on the highway and when coming to a stop. Everything else is as normal.
My next step is to install the OEM
@1world1love ..This is great to know.
My rig has full steel front and rear bumpers and skids and slider with rooftop tent. Added quite a bit of weight.
While I was traveling, with full gear and 2 spares, the car had a real hard time rising to H. I would like to try this option with the same springs as your set up. Ultimately I would like to do a sensor lift for a permanent 2 inch lift with option of raising more with a switch. Hopefully these springs can help me with that.
Do you have the part numbers for those springs?
I looked in the trail tamer website but couldn't figure out exactly which ones I need.
Thank you!
Awesome information. Thank you those tips.Hi. If I were you, I would do the sensor lift and spring replacement at the same time. Both are likely to necessitate an alignment so best to do that once.
Do not try LC springs. They are entirely too stiff and AHC will not function and you may damage something.
The part number you want is TTCS-2168. Cruiser Brothers is the official distributor for TT in the US so just email them. It took about three days after ordering for the springs to show up at my house so definitely the way to go.
Post some pics when you get them installed.
Agreed LC springs even with that build out would be too stiff.
As a baseline frame of reference, here's some rear spring rates for comparison. Too bad I'm missing the LX570 stock spring rate which is likely between the LX470 and King KTRS-79.
Spring - Spring rate (lbs/in)
LX470 AHC - 95
LX570 AHC - ???
King Springs AHC KTRS-79 - 130
LX450 - 150
LC100 - 170
LC200 - 170
More LC200 aftermarket springs for kicks (which IMO are far too high, even for some built LCs)
OME 2720/2721 - 270-340
OME 2722 - 275
OME 2723 - 340
OME 2724 - 400
The AHC hydraulic accumulator based support is progressive by nature. So pre-loading the springs (using 30mm spacers) rather than increasing the rate (King KTRS-79) may be just as effective. At least that's my experience going up to 2000lbs payload and the system works just a stable.
If your rear payload changes much, I would recommend airbags. Good off-road performance and articulation generally wants the lightest spring rates possible. And only as much increased spring rate as necessary, to handle payload. Otherwise the vehicle becomes a stiff legged 3/4 ton truck that doesn't like to articulate or absorb irregularities.
BTW, may be I missed something but did you do anything to the front springs or upper control arms while doing the sensor lift?
Although biggest weight increase is in the rear, the front does have some added weight due to steel bumper, winch, dual battery, air compressor etc. Although AHC is able to raise the front rather easily with this set up, I was just curious if a preloading spacer would be useful.
I will try the sensor lift with swapped spring as you suggested. Will post before and after pictures.
Thank you!!
Keep us updated when you get this done.I have a set of OEM spring spacers that I am going to install on the front but have not yet done that. I would recommend it, but it is a more involved process since you have to bleed the AHC to do the install. I am waiting for my next flush to install mine.
forum.ih8mud.com
I just ordered mine today. I will try to get it installed soon. It came out to 414. Shipping from Australia was 175.Any update on this? I do plan to add my rear steel bumper which will increase weight in the rear and I will order the TAMER springs to accomplish that.
I need to increase the spring rate in the front, it is to low in High mode.
If a spring rate increase is NOT recommended then am I correct to assume that a 30mm spacer will be sufficient?
Cost is not a factor, all that matters is the ride quality to be the same.
I have done the sensor lift already and am able to comfortable run 35's. The issue is I have already added a lot of item in the front. Winch, bumper, lights, battery and more. I guess when I noticed the front sag lower it was after the bumper installOne of the AHC gurus may chime in more accurately, but I wouldn't expect the addition of spring spacers to do anything to the height at all. AHC will act differently than traditional suspension with the addition of spacers. Instead of forcing the height up, it will instead compress the spring down. The height is controlled by the sensors and the system will always "self-level". In reality, level is up to interpretation I guess, because my rake has always varied for reasons that I have never understood.
Regardless, if you want to raise the front, you can adjust the sensor brackets in the front.
I would also add that it is not necessary to upgrade your rear springs just because you add a bumper. Plenty of people have bumpers and lots of other mods and have no issues at all. I never experienced any myself other than increasing slowness in going to H. It is true that my ride improved when I installed the uprated springs, but again, I am usually significantly heavier than stock. I am not sure a bumper alone would cause any negative issues for you. YMMV though.
Adding the factory spacer in the front strut will not lift the truck as @1world1love pointed out. What it will accomplish is preloading your front springs therefore increasing the spring rate. So i think the general recommendation would be to try adding the OEM spacer and see if that gets your front end back in shape.Any update on this? I do plan to add my rear steel bumper which will increase weight in the rear and I will order the TAMER springs to accomplish that.
forum.ih8mud.com
Maybe check out this thread:
And this one
OEM Front Spacer Install for AHC Suspension
forum.ih8mud.com
I received trail tamer springs TTCS 2168 set.
They are both the same. I expected one to be higher than other for driver side and passenger side. Am I missing something here?
