LX 470 (10-2004) Supercharged (Bulletcar) Dyno
Hallo hoser
Thank you very much for your information in the attachment.
I look to the bills and I found that the transmission repair shop specified the Brand name of the gearbox oil used with the name Type WS which I believe stands for Toyota world standard transmission fluid.
When I go the next time to the repair shop I will ask them to install a temperature gauge for the gearbox.
I remember when I have had the gearbox problem a red warning light came up which must be for the Oil gearbox gearbox temperature.
Now I have had my car back for about 10 days form the repair of the torque converter and the repair shop owner told me that they have had checked everything in respect to the gearbox including the oil cooler.
After the repair the driving of my gar has had no problem and is very smooth!
Thank you very much!:)
Hallo SaadUK
"What's the 0-60 mph approx timing on your sc v8? Can u please post a video of how it goes as well if possible."
0-100km/h
I have made a video but I have no idea how I can directly attached the video here!:confused::frown:
Hallo SaadUK
0-100km/h
Dear Wernerv, you can upload the video on YouTube and paste the link of the video here. Thanks.
Hallo SaadUK
On the Dyno we tested the car with the top speed of 213.64 km/h.
The LX470 speed limit of 180 km/h was removed by using the the Unichip piggy back!
However, it is strongly not recommended to use this kind of speed on public roads!
Thanks for the video. I am surprised to see that my stock LC does in almost same time as the bullet sc. what can be the problem???
Hallo SaadUK
"Thanks for the video. I am surprised to see that my stock LC does in almost same time as the bullet sc. what can be the problem???"
I can not tell you this!
The only I can tell you is that my car got around 100 HP more and according to my understanding it is much more faster and powerful as it was before! But this is only my understanding!
If your car is doing the same I can only recommend to you do not make any modifications on your car to improve the power!
I would appreciate if you could show a video of your car with the acceleration as I have done here.
Thank you very much in advance!:)
I will make a video once my TRD Supercharger is installed. By my count it looks like you have 0-60 mph (0-100 kmh) in 9 seconds. Isn't stock 9.4 seconds?
I noticed no wheelspin on initial take off in the 0-60 video?
Normally when we fit these, more than 50% throttle in 1st gear means changing lanes, and front wheels spinning madly, when accelerating from a standard stert.
Hallo SaadUK
Thank you very much for your for your Video. Your car runs well! :)
Please keep in mind that with my 22 inch wheels and tires 305/45/22 my speedometer is 5.7% slower!
In addition switching as well the speeds in the gearbox based on the larger tiers earlier!
This means a slower acceleration!
hot dang , $13k
For that much money I’lltry to put a 6.6 durmax in my hundy
But I love bulletcar’s diesel conversions
Hallo SaadUK
"What I mean to say that the amount of $$ you spent on SC, UNICHIP , exhaust etc is not justifying at all."
Please consider in your judgement the change of my tire size which is a calculated 18% drop in the gear ratio that I got with the switch to the larger tire size! Effective ratio is vitally important since it is directly relative to the vehicle's torque output and acceleration.
Larger tires are making the acceleration slower.
Smaller tires providing acceleration gains.
Again my tire sizes is 305/45/22.
I do not know what tire size you have on your car but I think the are smaller than my 305/45/22 inch tires.
wenerv - seems quite healthy to me! It's hard to get a sense of speed directly from these videos but yours most definitely pulls better than SaadUK - especially considering the larger wheel/tire combo you got there. You can really tell in how quickly it pulls through second gear.
Hallo TeCKis300
Thank you very much for your comments. :)
For me the car after the modifications runs very well.
The only weak point in the car is between 130-140 km/h. During this speed it is like the car has a small "Turbo Hole" and when its comes out of it is going up to its speed limit quite well.
However, driving a high speed (>130 km/h) in the LX470 is not recommended!
Again thank you very much!
Dear TeCkis
The reason for me to upload the video originally was, I suddenly felt loss of power and the 0-60 mph went down to 9.5 sec. I am still looking for the reason. The car vibrates slightly at idle.
