For Sale LTT-FE Military Trailer - Wisconsin (New pictures)
Shawano, Wisconsin
Hi everyone, I picked up this LTT-FE last year as a project trailer for an ice house but have just been to busy to get to it so I thought I would put it up for sale...$2250.00. This is a tough aluminum trailer made by Schutt Ind in Wisconsin, a great project trailer. Below are the specs on this one. I'll get some better pics uploaded this week, these were just a couple I took when I picked it up. I do have a wiring harness converter and a new pintle hitch that will go along with the sale.
  • OVERALL LENGTH: 167.5 inches (425 cm)
  • DECK LENGTH: 120 inches (305cm)
  • DECK HEIGHT: 34.5 inches (88 cm)
  • OVERALL WIDTH: 86 inches (217 cm)
  • OVERALL HEIGHT: 45.5 inches (116 cm)
  • TRACK WIDTH: 72.5 inches (184 cm)
  • GROUND CLEARANCE: 16 inches (41 cm)
  • TIRE SIZE: 37 X 12.50R 16.5LT
  • RIM SIZE: 16.5 X 8.25 HMMWV standard 2-piece steel wheel
  • MAXIMUM VEHICLE WEIGHT: 4200 lb (1905 kg)
  • CURB WEIGHT: 1350 lb (612 kg)
  • MAX PAYLOAD CAPACITY: 2850 lb (1293 kg)
  • DESIGN: Frame and body are composed of aircraft aluminum alloy with reinforced high strength steel drawbar and sling/tie-down points.
  • SUSPENSION: Independent Rubber Torsion Axle
  • SHOCK ABSORBERS: Hydraulic, double-acting
  • ELECTRICAL SYSTEM: 24 Volt system
  • BRAKES: 12 x 2 inch inertia-actuated hydraulic surge brake system. Independent hand-brake levers for left and right side parking brakes.
  • DEPARTURE ANGLE: 27 degrees
  • TURNING RADIUS: 80 degrees
  • FORDING: 60 inches (152 cm)
Did you ever sell this trailer?
lol, 8 years later…:popcorn:
