LSPV Clarification
Santa Cruz Mtns
Hey All,
Reading a bunch of threads on the LSPV... and "think" i found my answer but got confused with information overload. This is a two part question for clarification...
#1 - I have a new LSPV installed on an ABS '96 (bumpers f/r, sliders, air bags, winch, etc. = heavy). After replacing the valve and bleeding the brakes... I noticed the plastic "guide" on the valve ,where the metal bar attaches, did not line up correctly so decided to leave it off and try driving it for a bit (this is also after reading some threads on mud). Its been at least 2 years and braking works well.
The question: Based on on my configuration (no bar attached), is the proportioning set to 50/50?
#2 - All that being said (above), this truck is used as a tow vehicle for our small travel trailer (roughly 3.5k lbs.)
The question: Can I expect to see more rear brake pad wear? Would re-hooking up the LSPV help to disti the braking power better?
Thanks! :beer:
According to this, it would seem that without the bar attached (load-sensing spring) the LSPV would think the truck is unloaded, therefore biasing the braking force toward the front.
Thanks for the pdf. Reading through it now.
Also, has anyone ever installed a valve and not had it line up? Maybe I just started the threads in the wrong position? (thought I would ask)
If your rig is lifted you need to compensate for the alignment of the bar.
Totally agree. I have removed it completely though. The valve is installed but no bar (for some time now).
That bar transmits the rear axle compression from weight to the valve with the intention of adding more breaking force to the rear. If you e removed the bar, it will do what mine did when I lifted and didn't have it adjusted...put all the braking force up front. I cut the arm on mine off last Monday and used a piece of scrap steel as a bracket and mounted a female 1/4 heim joint over the remaining nub and threaded a 1/4-28 screw down through the above bracket and cinched the arm all the way up. My braking has never been more responsive of powerful. It's wonderful having all 4 break calipers working for me again.
Thanks for that reply. I think I saw a pic of this in another thread. Do you a link or the actual pic handy??
IF the lsvp is properly adjusted, and the rest of your brake system is in good working order, you should be able to STAND on the brake pedal on a gravel road without the rears breaking loose, and without the front of the rig nosediving.
Thanks Inkpot.
Attached image shows how the plastic alignment slot of LSPV is off and does not lineup. Thinking I got that wrong one (oem) or would just hook the dam thing up and mess with the adjustment.
That blury bolt head in the foreground is exactly where the arm attaches.
I can go snap a picture real quick...stand by
The whole setup explained.
A piece of 1"x .125 steel flat bar from the scrap bin with holes already drilled from the last project was bolted up to the bottom right bolt of the LSPV bracket. From there I spun one 1/4-28 nut all the way down a 3" long 1/4-28 screw. I placed a split-lock washer and a standard washer on it and put it through the existing hole in the flat bar. Then I put one more flat washer on an spun 2 more nuts onto the screw. The I placed the heim over the cut off LSPV arm and screwed the screw all the way into the female heim joint. I then locked it down by tightening one nut against it. Then I used the upper most nut to adjust the LSPV Rod all the way up and then tightened the other nut up to the bottom of the flat bar. Viola, manually adjustable LSPV.
Parts list:
1- 1/4-28 threaded 1/4 through hole female heim joint
1- 3" long 1/4-28 screw
2- Flat washers
1- locking washer
3- 1/4-28 nuts
1- 4" peice of flat bar
  • Like
Reactions: RFB
Parts list:
2- Flat washers
1- locking washer
3- 1/4-28 nuts
Great stuff! Thanks!
FWIW, I just went out and figured out a way to turn that plastic alignment piece reinstalled by LSPV bar. Driving it tomorrow so lets see how it goes.
Parts list:
2- Flat washers
1- locking washer
3- 1/4-28 nuts
now that' some cool s*** right there, I don't care who you are :hillbilly:
Thought I would report back...
After reinstalling the LSPV "arm"... braking is improved (obvious I guess).
However, I still feel there is a bias to the rear both before and after installing the arm. Taking it out to some dirt roads in the near future to mess with mashing on the pedal and adjusting.
Cheers and thanks everyone! :beer:
