I've just pulled the rear diff to install a lockrite, and found it's a LSD. Nice surprise. So now the plan is to pull the front, put in the lockright, put it in the rear, then put the LSD in the front. Does this sound like the best plan? I've got no power steering & have been told a front locker without is NOT a good idea...
The real question is to do with tightening the LSD..
I've never played with one before, but it's obviously not very effective because it behaves like an open diff. Could that be becuase I've been using the wrong oil - hypoid 80/90? I've unbolted the clutch pack but don't know what it should look like, but I guess in an old 40 it's probably worn out. Is it just a matter of getting new clutch plates & bolting it back together?
As an aside, there was quite a bit of metal sludge on the drain plug, which I was a bit concerned about. Or is this just from wear in the LSD clutch pack?
Any other tips or advice gratefully accepted.
Thanks in advance - this forum has never let me down!
