LS fuel pump
I am still running the same Denso 1FZ pump for like six years now silently and problem free. Of course I'm going to screw it up soon since I need to make some changes to support +500hp :lol: Bye reliability.
Do you know if there is an equivalent inline Denso pump?
I did an LS Swap into my FJ62 back in 2016, and we went through the decision tree on what pump/filter/FPR/etc. to use. I wanted to go full Aeromotive but my brother talked me into the simplest, best route (in my opinion) that few others seem to be using.
We swapped a GM (Delco) EP378 pump for the factory fuel pump; perfect fit in the factory bracket, no mods required. In-tank solution and quiet as a mouse. Runs 58psi at the rail, running through a Wix Corvette filter (with return to the factory tank using factory return lines) on the frame.
After nearly 8 years, it finally gave out last month (fairly common for the GM fuel pumps). I dropped the tank (not fun on a 62) in the driveway and swapped it out for the same thing. Buttoned back up and turned over on the first try, no issues.
Hi, What did you use for the electrical connector? I see the pump on Amazon, but not the pigtail. Also, the suction strainer (filter), you said it's a Six for a Corvette, is that a pretty standard part? Does it come with the black base? Want to start to collect stuff to be prepared. Thanks!!
