Electric fuel pumps traditionally pump better than they suck, meaning - locate the pump close as possible to tank. I believe that's why many OEM pumps are actually in the tank. I originally had my pump attached to the the floor, but moved it to where it is now. In front of the tank, below the top of the tank, near the rear panhard rod, similar to @Outsane 's location.Great thread guys. @Outsane @80t0ylc any longer term feedback on pump location? Kicking around optimal spot...probably doesn't matter assuming it's not excessively far away from the tank and also correctly placed vertically (latest instructions state 12" from bottom of tank to pump). We were going to catch one of the captive nuts on the floor like originally posted in this thread, but considering dropping down a bit based on the feedback here.
And any suggestions on pulling 12v power? Cig lighter? I'd like to be able to run it when the key is out/truck is parked.
Excited for the extra range. And to install that clean Solvefunction knockout for the LRA gauge...so clean! Appreciate the guidance on the wire routing as well - aiming to follow that.
Thanks guys!
Good power connection on it's own circuit (not shared) would be my choice and as @Outsane mentioned, fuse is important. Not real excited about running pump with the ignition off. It's real easy to get distracted and not get back to the rig to shut it down, as necessary. As much as it seems like a good idea to pump fuel while the rig is parked, the negatives of what could happen when your attention is compromised, to me is not worth it. And for safety's sake, it makes sense for pump not to run with key off.
