Hello Fellow Mudders!
I will try to keep this short, but here are the basic problems that I am having....
-During Start up the volts are showing 13.4-13.1
-As soon as an load as put on the system it drops dramatically to 12.0-11.8 (may recover to 12.2 but only occasionally). This is can be when I stop at a red light or whatever. Seems more prevalent when the vehicle is warm. During normal driving down the road it is steady at 13.1ish.
- I changed to a Diehard group 31 exactly 1 year ago.
- I thought it was the alternator/voltage regulator so I changed it....same issues.
- I thought it could be a ground issue so I upgraded the ground wires on the battery and the block...no dice.
- I thought it could have something strange drawing it down from the fridge, amp, or winch so disconnected those....same problem.
- I brought in the battery to Sears and they tested it and said it tested good. I still believe there is a dead cell in the battery or it is sulfated (I don't know if they load test it or what), but I am not sure how to get them to change their synopsis. With nothing running the battery is showing 12.6-12.8v. The truck always starts fine, but I am sure it would even with 5 cells in that big honkin battery functioning ok, plus I drive about 70 miles a day to and from work so it gets a decent charge on the interstate. Even still....this isn't right.
Any thoughts on this issue? Any help would be greatly appreciated.
Thanks,
Josh
Thanks,
Josh
out of luck? Sucks, but that may seem to be the case here. I just kept hoping that wasn't the issue, and with 230k miles on the odometer I figured the rig could use a new alternator anyway.
Always good to get some fresh advice from the mud community on a path forward.
