Low Range Shifter Stuck
Brisbane Australia
Can't move the Lowrange shifter from high to low.
Tried spraying the linkage with WD40 but still no luck.
Any suggestion on how to fix
Did you put the main transmission into Nuetral?
I had the same propblem for a while, you are going to have to take the transfer case shifter completey out and soak it pb,tranny fluid,wd whatever you preffer and it will free it up, just remove the shifter console there is 4x 12mm bolts i belive and remove the coter pin and it will come out.
i assume you tried to reverse it for about 30 feet and it didnt come out?
It's a manual transmission.
I think the problem is somewhere within the linkage system
So all this can be done from the floor access hole around the shifters. I had a look at this earlier and it appears that it will be necessary to remove the carpet to get the cover plate and rubber boots from around the shifters
My experience is only with an auto and fulltime 4WD transfer. I would first disconnect the linkage from the shifter and see if you can manually move the linkage on the transfer case. If the linkage moves easily, then the problem is the floor mounted shifter.
On mine the shifter lever had siezed. It was a bit of a PITA to remove access plates in the floor simply due to rusted bolts, but an easy repair in the end. I packed the bottom of the shift lever where it mounts to the top of the tranny with moly grease.
no need to remove the carpet, u can slip and slide them once u get to the screws holding the steel plate under the rubber iirc, ur set.
if yours was used regularly and then suddenly stopped shifting in or out, then u have to check out ur transfer case.
i had the same thing happen to me, when i first got my truck, previous owner never put it in 4wd, so it will not go anywhere, once opened i sprayed it with wd40, wipe the dirt out, then soak it, it became tough to shift, but it worked after a day it was smooth, didnt look back since then.
the saying of "use or lose it" holds true here.
I found it easier to pull the carpet up and while i was at it took itr ight out and did a bit of spring cleaning. The problem was with the shifter pivot. Got it soaking so hope it will loosen up. Seemed to get worse after a couple of beach trips.
