low range/overdrive/lx450
Tmax
15 Year 10 Year
is it me or does it not feel like my LX450 does not shift to overdrive in low range????
Overdrive in low range?
i took her out again yesterday and i'm pretty sure the overdrive does not kick in 4low. maybe this is a lexus setting.
haha. yes i totally want:D
how do i do it???
:beer:
I thought everybody knew that one. First ya gotta learn the secret handshake, and then.............:hhmm: I can't remember. Oh, yea, now I got it. On the rear of the transfer caase, up on top, there are two plugs. I am pretty sure it is the one on passenger that you need to unplug. If I am wrong, you can just redo and unplug the other one. HTH JOHN
Because you're doing 40 MPH. If you're able to do 40, why would you be in low? To see how fast you can spin gears inside the transfer case before it explodes? It makes no sense to me.
So those same gears are spinning the same speed if I'm doing 90+ on the freeway, so we're all gunna die?:hhmm: Also, overdrive in low range gives you a little less rpm and a little more mpg on the easy trails. You don't have to run wide open throttle just because you are in OD.
Have you looked inside of these transfer cases? I have been running and repairing industrial gear boxes for over 40 years, and these transfer cases are built really well. I have no hesitation to low range OD whenever it is convenient. Nobody said YOU have too. John
I do it quite a bit. IMO, traction and handling are better in low than high, you also don't need the brakes very often.:steer:
having a wider range of speed in a selected range is always handy and helpfull. if the tc locks up, then its even another plus as less heat is generated in the trans.
so what are the ill/side effects if the plug is left disconected all the time?
btw thans for the tips.
