having a wider range of speed in a selected range is always handy and helpfull. if the tc locks up, then its even another plus as less heat is generated in the trans.
so what are the ill/side effects if the plug is left disconected all the time?
btw thans for the tips.
It might change the shift points a bit. I dunno, that switch has never worked on my LC since i've had it, so i have to use a button to lock the center diff (when i put it in low, the center diff does not automatically lock). Being that way, i always assumed it was normal for the thing to engage 4th gear in low, and yes, the torque converter does lock in low as well. It will will get in 4th gear much quicker than 40mph as well. Not sure what speed it is, but at 40mph in low...that thing is singing.
but with 2nd gear LR starts you most likely will never notice.
