Low Range Gears - FZJ-80
Petty sure I'm running in OD, but questioning.
Based on butt dyno, seems that unlocking the CDL afforded a taller gear, presumably OD. It's an improvement, nonetheless, due to not requiring shifting back to 4H on less intense portions.
@ LandCruiserPhil,
Any further observations on the motor mount issue?
@ LandCruiserPhil,
Overreaction on my part...motor moves a lot more with this mod enough for my aftermarket exhaust to make contact under heavy load. :o
You can test for OD in LR by hitting the OD button at 30mph. :D
Well, got Robbie to install my low range set up as well as a part time set up.
We replaced every single bearing and oil seal.
And, while I was at it, I went with a new A343F tranny too.
:grinpimp: :wrench:
Install next weekend.
:grinpimp: :wrench:
Which part time setup did you end up with?
:grinpimp: :wrench:
No neck snapping shifts for you!:cool:
Anything special mods necessary when upgrading to an A343F or were you already on board with a A343F?
and this is to be retired after Dusy?
Your must just mean the carcass for as much love as the drivetrain has seen :D
