Low idle when HOT - next steps?
Reviving this thread again to see if there were any solutions found? I have a ‘91 and also went through the fixes originally stated plus more.
I was starting to think it was just due to old gauges, but it seems to be a common thing.
Download the Toyota FSM and EWD from the resources section.
Also, please read through this document:
Idle speed is controlled by the ECU pushing the ISC valve.
The "golden screw" is NOT an idle speed adjustment. It will have a temporary effect on idle speed, but the ECU will continue to push the ISC to get the correct idle speed, or what the ECU "thinks" is a correct idle speed.
If the ECU is getting false readings from its sensors, or there is unmetered air entering the system, this engine will never run properly.
The top half of the engine wants to be air tight. Any unmetered air will play havoc with idle speed.
Oil fill cap gasket, oil dipstick gasket, valve cover gasket, valve cover grommets are prime sources for air leaks.
All sensors should be checked and verified according to the FSM.
Also this thread just popped up and it relates to IACV:
Appreciate you jumping in sir. There hasn’t been a thread in which I haven’t seen you share knowledge. It is much appreciated!
I’ve downloaded your guide and going to make sure all are crossed off the list.
Since I’ve acquired the car I’ve done the following maintenance. A majority of these were done to pass smog, fix stalling issues, and general PM. It’s running great for the most part, I just want to dial that low-ish idle to make it perfect now:
  • EGR vacuum modulator replacement
  • EGR vacuum modulator hard lines carbon cleanup
  • EGR vacuum hoses
  • Distributor cap
  • Distributor rotor
  • Check Spark plugs
  • Spark plug wires
  • Ignition coil assembly
  • Clean mass air flow sensor
  • Clean Idle speed control valve
  • Replace PCV Valve
  • Replace PCV ventilation hose
  • Cleaned throttle body of carbon buildup
  • Check Fuel pressure regulator
  • Change Fuel pressure pulsation dampener
  • Replace Throttle position sensor
  • Clean fuel injectors
Thanks for sharing! So when I first got the truck, cleaning the IACV was one of the first things I ended up doing since it was actually idling high. It had a ton of carbon build-up on it but after cleaning the plunger part up, it brought it down, but then I started stalling while at a stop.
Learned that was due to carbon buildup in the throttle body. Cleaned that up and fixed the stalling, but now it just seems a tad low. It doesn’t surge anything like the video in that other thread thankfully, but like other were experiencing in this thread, it just feels like it stumbles a bit once fully warmed up to operating temps.
Had a smoke test done, and could not locate any obvious signs of a vacuum leak anywhere, but could just be user error on my end not being able to locate it.
The smoke test is a good one, and I usually disconnect the large vac hose going to the brake booster and stick the smoke tester nozzle in it. This fills up the entire intake manifold with smoke and starts leaking out of hoses/nipples/etc.
I didn't know about the fuel pressure pulsation damper, need to see where it lives! You're being meticulous with everything so I'm sure you'll solve this issue in no time.
Did you test the idle control valve after cleaning it and the passage (run through all of the little steps from open to close)?
How about the throttle position sensor adjustment (with a voltmeter)?
Have you disconnected the battery to reset the ECU after these adjustments were made?
Thanks! And as for the fuel pulsation dampener, it’s kinda in an awkward spot in the back of the engine bay.
These two videos were the only ones I could really find that shows how to get to it:
And I got mine from here for what it’s worth:
Hey Zack, thanks for the input! So I haven’t run through the actual tests to see if the IACV is running through all the steps properly. For that part, I’ve just assumed it was working properly due to hearing the clicks when shutting off the engine and the fact that idle changes when I turn the AC on/off.
Re: the TPS adjustments using a voltmeter, I have not done that either. I had just replaced the part entirely since I found a good deal on an OEM one and figured it would be good to just replace. This is my first “project” car and I’m trying to learn as much as possible so I’ll definitely look into that!
@ZackR brought up an excellent point.
Anytime you're working under the hood, even for a simple tuneup, best practice is to remove the 15 amp EFI fuse in the relay box on the left fender.
That's FUSE not relay (circled in blue). Less invasive than disconnecting the battery.
Removing that fuse kills power to the ECU and clears out any old error codes stored in memory. It forces the ECU to "relearn" all the sensors.
Typically, your idle will be higher than normal for the first few drive cycles until it relearns.
The items in your videos aren't pulsation dampers according to my FSM, but I have a '96. Perhaps they're called pulsation dampers for the 3FE? These are simple fuel pressure regulator (FPR) that are in front of the engine. It takes five min to pull it out! I'm not sure what's behind the engine that's fuel rated, other than where the fuel hose comes from the filter to the fuel rail.
Like a few legends have prev stated pull that EFI fuse ( it’s best on a cooler morning / dead cold engine ) and let the engine warm up 100% at idle. It’s possible the computer was compensating for lots of small issues with air flow and other systems and found a happy medium. Now that you have a lot of components cleaned up it’s having a harder time putting the tooth paste back in the tube, better to pull that fuse and let it refigure the parameters of how things are now. Older tundras and sequoias used to not even run after a battery dump if the throttle body was dirty and you didn’t know it, you clean that throttle body and wham bam Christmas ham you’ve got a runner.
The 3FE has both an FPR and a FPD.
The fuel pressure regulator is located at the front of the fuel rail similar to the 1FZ.
The fuel pressure damper is located at the rear of the fuel rail and is a PITA to get to. Don't forget to replace the 2 crush washers on the fuel line banjo fitting.
A crow's foot wrench comes in handy for R/R.
The FPD is essentially a very small expansion tank with a diaphragm that absorbs fuel pressure pulsations as the 2 sets of 3 injectors fire.
The 1FZ fires injectors individually, so there is very little pulsation in the fuel rail.
That's a great explanation, thanks Jon.
Oh yea, and re: resetting and clearing the old codes - I do unplug that 15 amp EFI fuse after repairs (I believe I actually learned that from you on a separate thread while hunting for solutions to a different problem lol!), but still ultimately ends up finding the base idle in the photo shared a few chats up.
Like I said, everything seems to be running great other than this last little issue so it’s not exactly an urgent thing. I just plan to keep this vehicle as long as I can so all of this is just in attempts to give it the best life and have it running like a top.
I’m going to go through that document you shared and really ensure all of it is addressed properly. Will be sure to update everyone as things progress, but always open to more information/suggestions! My first time coming to a forum to ask for help and I really appreciate the support from you all.
