Low gas mileage
Malleus
contact@Restore4x4.com
Supporting Vendor
Charlotte, NC
OK here's a stumper. Malleus the Younger got his 80 a couple of weeks ago. We removed a bunch of PO crap and cleaned it thoroughly. In the process, we replaced all the usual suspects:
Plugs and wires, (the PO had Bosch plugs and wires; ughh)
Distributor cap and rotor,
Air filter,
PCV valve and gasket,
and, just because we didn't have anything else to do, we cleaned 95% of the accumulated tar out of the throttle body. It was nasty. The intake wasn't too bad actually. I'm pretty OCD, and I didn't think it was worth pulling it to clean it.
It has 274+k on the clock, but the engine runs really well. I could balance an egg on the valve cover. It idles rock steady at 650 ±5 rpm. The PO claimed he had a P0130, but I didn't see when we bought it, and the CEL was clear for about a week after the work. Now I have it. The old plugs weren't bad; a little oily on #5, but the others were nicely tanned.
I checked the mileage from the records we've been making since we bought it. We got 8.2mpg on the way home (all interstate driving) and are now getting 9.6mpg (around town). This is with only two tankfuls, so I'm hopeful the mileage will improve.
This is his DD, and his drive to school is all of 10 minutes. We're dumping fuel somewhere (no fuel smell though), because it runs too well not to be getting close to 13mpg, which my other two 80s do. I'm not really concerned with the mileage per se, just that's it's an indicator of performance. I have no dependable description of previous maintenance, other than that the engine bay is reasonably clean. (my definition of clean)
My first thought was to pull the injectors and test them for operation and flow. I'm open to suggestions on how to proceed.
O2 sensors? Or maybe ohm em out first.
Some folks have reported noticeable gains after a fresh set of densos (oem)
I noticed a big difference after I replaced both cats(due to corrosion). Significant improvement.
Don't know how you'd test for exhaust restriction though, that might be a stumper...:meh:
I considered both oxygen sensors and new cats, but I wanted to try engine related solutions first, only because I hoped they would be simpler and cheaper. The truck needs news sensors, cats and probably a new Y-pipe. The tubing hasn't failed yet, but it's not far off.
Here is what it looked like, after a minimal wash. I want Malleus the Younger to post the truck photos (I don't want to steal his thunder), he hasn't gotten around to creating an account yet.
Here's the throttle body. The "after" photos weren't illuminated properly (you can hate my phone, I do), but the face areas relate to the interior pretty well. Note the completely blocked PCV port at the top. The volume of tar in there equalled my little finger.
That's just trash talk...
I had an issue with my old 4Runner where the mass airflow sensor was starting to go bad causing the engine to run rich. It might be worth giving it a cleaning and see if that helps any.
Did you unhook your battery to allow the ECM to reset to start over it's "learned" settings? If so, it takes something like 30 restarts for those setting to lock in. I occasionally unhook my battery to clear the settings, particularly before a long trip because my city driving habits will influence how the mileage is on the open highway. I will get better mileage if I reset, THEN take a trip.
Also, if it's only running for 10 minutes, it's not getting fully warmed up and is still running in OPEN loop. Think of it like driving with the choke on. It's dumping more fuel into it to keep it going since it's "cold".
Once it hits closed loop, the fuel pump pressure changes and the on/off timing of the injectors and what the computer does to the signal from the O2 sensor modifies. It also affects total timing.
I have a 98 Chrysler T&C that gets about 8 MPG because the wife drives it less than a mile each way to drop off/pick up the kids. When it hits the highway, it gets about 16. Ti still sucks, but it shows the huge difference.
My LC gets about 12 most of the time because I have a 14 mile commute that lasts between 20 minutes to 1.5 hours, depending on traffic. Open highway keeping it at 65 or below and I will get 16. Above 65 and I get 13.
That's on my list. Now.
I used my OBDII reader to clear the code. I haven't unplugged the battery, but I did pull the 15A ECU fuse, several times, when the CEL came on, after the baseline work.
I told him last night that if we didn't see a significant improvement in mileage after this tank is run out, I'd take it for a week. My commute is much longer and I can run a tank out in four days.
I didn't mention it in the OP, but the first tankful was 87 octane gasohol (we were "on the road"). Last night's tankful was 89 octane gasoline. I use only pure gasoline in my 80s (and small engines). We have a choice in NC between real midgrade gasoline and 10% ethanol "enhanced" swill. The LX570 can stand the rotgut PGA mixture, but the old girls don't like it.
I doubt it will cure your problems, but I always run at least one bottle of Lucas injector cleaner through a car whenever I buy it.
Other than that I would definitely get some MAF cleaner and spray the hell out of it, then start looking into sensors.
Sounds like a plan
How does the base ignition timing look? Once thats dialed in (I have mine at 8-9 degrees) keep doing the Italian tuneups on the highway and after a few more tanks of gas report back.
That's an interesting question. I've only looked at it while parked in the driveway, but it seems to be running about what yours is. I'll need to look again this evening.
Why don't you put together a list of PM you need to do and what has been completed? Once the list is completed then we can spend time to troubleshoot the gas mileage thing, you gotta do it anyways.
Let me help you to get started:
Fluids:
Oil change
Tranny fluid drain and fill
Diff oil change
transfer case oil change
replace brake fluid
flush and replace coolant
Replace parts:
Replace all vacuum hoses
Replace all coolant hoses
replace intake hose
replace belts
replace O2 censor
replace air filter
replace pcv valve
replace spark plugs and wires
replace dizzy O ring
That should keep you busy for a little bit!
Not much more I can add but one thought is to use an IR thermo and ensure both cats are getting up to temp. They start to function around 4-600 degF and should be that warm or warmer. If they don't get that hot you are either too rich and they are shot or they are shot and probably clogged with soot from running too rich. Either way it would confirm replacement which is no fun since they are expensive but would then be critical path to addressing the problem. Otherwise, good cats running too rich usually get very hot.
Frank
