Lost O2 sensor wiring
Decatur GA
I have been looking around the forum but cannot find an answer to my question. I am trying to find out where the O2 sensor plugs in to the engine compartment? My sensor cable was cut while rubbing on the drive shaft. So it is not the sensors themselves. It is after that. So I have to replace the entire cable from the plugs to the sensors to the place where they connect in the engine compartment. But tracing it makes me lose it just over the tranny. If I can, I would like to run a separate set of wires down to the sensor instead of trying to splice everything in together if possible. I just need to know where it ends up?
I have heard that it really is not a good idea to splice these wires due to the shielding. Any thoughts?
btw 1995 F80 180K failing emissions on CO
The sensor wire that goes over the driveshaft jumps from a bracket on the frame right next to the O2 sensor plug, across over the top of the driveshaft to the top of the transmission. Near the back edge of the bellhousing. Then it goes along with the transfer case wiring into the main engine harness above the starter, under the intake manifold.
Basically like @blkprj80 said, you can't disconnect those wires anywhere short of the ECU plugs. You'll have to splice in new wires in the area above the driveshaft. And splicing shielded wires isn't that big of a deal.. just try to make the unshielded portion as short as possible, and connect the shielding on either side of the splice.
OK. I was going to solder the wires. Should I solder the shield too?
I went ahead and soldered the wires that were sheared and just placed the shielding round the cable the best I could and taped it on. I just got back from my emissions test and passed with flying colors. That was most likely the problem the whole time. Thanks for the help! But I still hear conflicting advice about repairing that wire. But without replacing the entire wiring harness, I do not know what else to do. I have heard that the repair can give a false reading which could be potentially dangerous to the engine.
If you passed smog and your not getting a check engine code, then your good to go. A more permanent repair could be done with shielded cable connectors if you can match up the size.
I believe it is a "projected" shield, i.e., it the end of the shield is unterminated (floating) at the sensor end. Somewhere in the harness, the shield is tied to ground I expect.
I can't see how repairing the harness would cause a failure, unless you did it with wire nuts or crimp splices and caused a resistive connection. If you soldered, cleaned, and insulated your splices, you should be fine. Even if it did fail, you'd be where you were before you repaired it, and your engine would be in open loop mode all the time probably.
I guess all in all, this could have gunked up my cats a little. I have no idea how long it has been since the wires were severed. No emissions are necessary in the county where I bought the truck. But since I passed emissions so well, I am assuming they are still OK. Before that though, my CO and HC emissions were through the roof.
