Lost a bolt
Omaha, NE
I was replacing shocks today and discovered a bolt/stud on the bottom of the knuckle had fallen out somewhere. What is it called please? Sorry the sun fried my brain and I forget the exact names of the parts but here is a pic. Thanks in advance!
Cory
Knuckle stud/nut/washer/cone washer. Check the rest of your nuts, 71ft/lb, they look loose. Also is likely low, empty on moly grease.
If the others were loose they likely stretched and will be no good anymore. Replace all of them. Also be prepared for the threads in the knuckle to be mangled on the one that fell out. They might not be.. but it's better to have all the stuff on-hand to deal with it if that's what you find.
With that amount of moly grease on the outside of your axle, instead of inside it, there's an axle rebuild in your future.
Good point. Personally I'd want the surfaces between the steering arm and knuckle as free of grease as possible for initial assembly.
How many are needed for an axle rebuild on a LX 450? 8 total?
get 10 so you have a couple spares. Can reuse your (still present) nuts,washers, and cone washers.. but I'd get enough of those to have spares as well.
But yes, 8 are needed for assembly. The top of the knuckle has two bolts each that don't often get lose.
Vise grips and a hammer. The new ones should have a 12 point head IIRC. Take the nuts off first and see if the cone washers come out. Install the new one first then work from there.
