Hi all,
Got a strange prob w/my 77 FJ40. yesterday, everything was running fine-- this AM I go out, start it up - all looks good-idle at 700, vac at 20" smooth idle. Raise engine rpm to about 1100, and vac starts dropping little more throttle and vac falls to about 4-5" -- engine quits. restart again idle is great, vac good. run the rpm up again-same issue-this time pumped the throttle and got rpm up to 2000, vac oscillating around10-15", engine is surging in rpm about 300up/down. can increase throttle up to 2300 and hold the throttle still and rpm/vac surges get worse, but it's surging on it's own while I hold the throttle steady. lots of popping out the exhaust .
First thought it might be fuel--(this engine has a Weber on it- also have an electric fuel bypass pump to charge the carb bowl if the truck has been sitting idle for a week or so))-intake air filter good, fuel filter good. turning on the electric pump along with the main pump didn't change anything. ok, so maybe the points has changed gap a little--they were a little closed up, so filed them, and re-gapped to .018. Cleaned the rotor contacts and the cap contacts-- no change to the way it acts now I'm stumped--
Has anyone experienced these symptoms before? what fixes did you try? Where would you go next -compression test?
Thanks in advance for any suggestions
Gary
Gary
