Looking for a Fabricator
New Mexico
I'm looking for someone who can design, build and install a trailing-arm independent suspension system to replace the poorly-designed system currently installed in this trailer. Or, alternatively, install a system like Cruiser Master or Curt.
I really want to know who you find, please report back. I have a similar trailer, and I’m trying to figure out how to modify it to make it a bit more useful.
Since my post I talked to Cruise Master and it looks like their XT system is the ticket. The components, swing arm pivot/mounts, spring/airbag and shock mounts can be welded to a fabricated subframe. The layout and welding done on a bench rather than upside down under the trailer. Then the subframe with welded components could be attached to the trailer frame. Seems like an elegant solution to upgrade an existing trailer.
Thanks, Mauser. I'm looking at my options and will be in touch.
This isn't a job for just any fabricator, but someone who has done "one offs", has depth/breadth to push themselves, and finally, one who has dealt with Larry's whims/desires for his 200 series project aka @Poupon :rofl: . Just because the company has "fabricator" on their sign, doesn't mean they want to tackle this kind of project. Heck, they may not even know how to quote a project like this unless this is what they do regularly.
Building a swing arm suspension on a trailer isn't all that hard, but getting it right, especially building alignment adjustments features into the design is critical. This alignment adjustments include toe and camber using the same hardware as any typical IFS vehicle. I prefer the usage of the alignment hardware and tabs for IFS 4Runners. I have air bags under mine, but I prefer coil springs. Sure, it's nice to be able to raise/lower one side or the other and all that jazz, but at the end of the day, dumb coil springs or leaf springs win the day for following the KISS principle. Do I beat on my trailer like it owes me money? Oh hell yeah I do, and if anyone who has followed me on a trail knows this to be the fact.
If it can break out in the bush, it WILL break out in the bush :hillbilly: I have broken the main leaf on my previous Kamparoo camper while heading to Kerr lake in CO. This was an Australian camper with Aussie "slipper" springs, but everything has limits, and in this case it was a case of metal fatigue. I wasn't sending this trailer over rocks or anything when this happened. After getting home that weekend, I went to McBride springs in Abq, and had them duplicate the same exact set of springs. I also bought a replacement 3500 # axle housing with electric and parking brakes from Dexter axles for my 2700# trailer. I saw no need to go all fancy with swing arms and all that for this trailer. I didn't feel like re-inventing the wheel so USA made leaf springs and an axle housing got installed, and I continued to beat on that trailer for another ten years or so before I upgraded to my current trailer.
There are multiple ways of going about this, but the cheapest way may not be the most robust way. I know we all know this already!
I'd contact Dom at Elude for a project like this. His input will be valuable in this type of project. .https://www.elude-expedition.com/?srsltid=AfmBOor0KRMIqZkYFiiukvqb7vC2uLsfozHneqKTksvgNvRoFyhA1xTq
Feel free to PM me if you want to discuss further or we can use this thread for a deep dive.
I only have this pic of the swing arms on my current trailer but I can take more if requested.
Do you think I would recommend someone that I don't think could do the job?
Hell, I had to cut the spindles off and reweld them on the same trailer you have because the manufacturer didn't do correctly.
My reply wasn't directed anyone specifically, rather it was a generic comment that everyone should be aware of. Sorry you took offense.
You worked on Matt's trailer which is the same company as mine, and if our trailers had alignment adjustability, then the problem would've been solved rather easily. In Matt's case, his toe was off. Hence my suggestion for having alignment adjustability for swing arms on trailers right from the beginning.
Our trailers are made by Adrenaline trailers out of Montrose (now shut down), and the trailers were modeled after Kimberly trailers out of AUS. Those trailers have alignment adjustments right from the factory, but ours didn't. :bang:
Indeed, Ali,
Dustin, the guy who conceived, designed and fabricated this trailer made a huge investment in time, effort and expense. And it all worked out pretty well except his suspension design. And he even had an engineer involved.
It took me a couple of years, many camping trips and numerous attempted fixes to realize, in my ignorance, that the design is flawed.
The problem is the placement of the airbags too far inboard creating a twisting force in the arm that no camber correction scheme could overcome.
To my mind the solution is to cut out the existing components and start from scratch.
Oh man, sorry to hear it Juane but it sounds like you have the solution in your head, just need help with the implementation. Additionally, Dustin is a top notch fabricator/designer, but this design has proven itself to be faulty over the long term.
I do believe I've seen turn key swing arms sold for any trailer application, but not sure of the vendor's name at the moment. If you searched on ExpeditionPortal.com in the DIY trailer section, the vendor's name might come up as there are tons of DIY folks in that forum.
LMK if I can assist further.
On my off road trailer, I kind of copied the GX470 suspension. Adjustable trailing arms mounted using bushings to isolate the vibrations to brackets on the frame and axle and pan hard bar to keep the axle aligned with shocks and air bags for a 1/2 ton pickup. Simple to build
dang, that's nice job Bruce. I love the overkill fabrication you did there. :hillbilly:
thanks, I just thought it out and I KNOW A GUY. LOL
your guy did a brilliant job from the looks of it. Is this person local to Abq or only to Pagosa?
