I appreciate that and probably need to be spanked for waffling so much. The good thing is that it's not going anywhere and he is totally cool for that price. Bad thing may be what we find in the inspection....
Ok, one more question for the pros, he said that it has the locking diff, it looks like there is options for multiple locking diffs? Can somebody explain that and how it may affect value?
afaik, for an 80 Landcruiser you can either have only a center locking diff, which somewhat improves traction by lessening the "slip", or spin directed to wheels that turn more easily. the other option is center, front, and rear locking differentials (from the factory - you can install just a front or just a rear if you go aftermarket). this is sort of the holy grail of traction, and definitely increases value, though you can add them later if you really want them.
you can tell if it has locking front and rear if there's a dial to the left of the steering wheel that turns and has "RR" and "FF" on it.
So is the "center, front and rear" all in one, or was there an option for each individual? As mentioned, he just said that it has the desirable "locking differential option".
Technically they all have a center diff locker some when switched into 4lo, some have a separate switch to activate the center locker when you want hi or lo. Those without the switch can be added for the price of a hazard switch, all the wiring is already there. The fr and rr locker is as said above on a dial to the left of the steering wheel.
I'm sure you don't have to worry about his but I will say it anyway... There have been multiple instances where the seller states that they have a triple locked 80 (meaning front and rear in addition to the center diff lock) but they don't. They have the switch for it on the left side of the dash but no K294 code on the MFG sticker on the drivers door. Read the below link. Post #8.
The data sticker is a good indication, but I know of several that have K292 on the sticker and have lockers, we swapped them. Also a couple that have the switch and no lockers, installed for fun. The the only definitive way to know for sure is to inspect and test drive to make sure they work.
True. My guess is your customers don't call it the "locking differential option" though. Doesn't seem like the type of lingo of someone that paid to have axles swapped. My guess is your customers actually use theirs and know what they have. Sounds more like someone that has never engaged the locking diffs to me.
Test drive it on some gravel. Stop, lock 'em up, and swerve back and forth. See if they are locked up.
Thanks for the info. The good thing is that I know the guy well, along with the two owner history. He bought it in '01. I just was not sure if there were options for front only, rear only or both.
Here is a preliminary smart phone photo. I will be doing a thorough inspection with my mechanic on Friday. So far, this thing is pretty damn sweet. The paint is great and a quick look underneath shows light surface rust in the rear at most. The only bothersome thing is that he has only flipped the diff switch once in 15 years. We will do it in the inspection. Is this something to be concerned about?
No. That's common with lack of use. Even if they won't lock up for you on the test inspection, through repeated attempts to engage them over time they will probably start working fine.
For reference, the last time I recall hearing prices for just the axle locker actuators was front around $700 and rear around $1000. Smart shoppers can get a nice discount, but it would still be some good coin. If you are able and willing the actuators can frequently be repaired and rebuilt, but that would be your risk if they don't work and you decided to buy it.
Not necessarily... Mine was a 1997 w/ 72,000 miles when i purchased it and the lockers were never used. Worked fine when I tried them on the test drive...
More of an issue would be rusted actuators from water intrusion that were never serviced, not so much from never used.
If it's got the rotary locker knob & you get flashing diff lights in cluster when you shift the trans case into LOW, with locker knob turned - it's :: probably :: worth the $8k.
The flashing lights in cluster mean the lockers are trying to lock, the bulbs wouldn't light if the switch was just stabbed in the hole (left of steer column, n dash) - flashing means the parts are all there & will work at some point.
That milage means you will be due for a $800 fr axle service (doing it yourself) - To me, that price, those miles, lockers & prob good outer/inner shape, plus '96 being a solid year (no 93-94 1fz oddities) ---- I'd buy it assuming rust is near none & no major damage to it.
