Looking at a 96- help
Not necessarily... Mine was a 1997 w/ 72,000 miles when i purchased it and the lockers were never used. Worked fine when I tried them on the test drive...
More of an issue would be rusted actuators from water intrusion that were never serviced, not so much from never used.
Best,
John
Trying to help the OP negotiate if at all possible;)
OK, had the inspection today. Here's what we found: No rust on body, light surface rust at most on undercarriage. Drives great, brakes great, looks great. Will be getting all paperwork of work performed in last 10 years. Probably needs a new muffler and tail pipe in next year. We could not get the center diff lock light to come on when shifting to low, but it feels engaged- did not drive on pavement. Both diff lights come on when flipping the switch, but again, did not drive. Is there a good test for me to check all three? Can I try the front and rear, even if the center did not come on? Owner does not know either, because as mentioned before, he's only done it once in 15 years. I am buying it this weekend but I do not plan on building it, only fixing what needs to be fixed and detailing it. It will be third family car and my son is turning 16. Thanks again.
No, the center needs to be locked before the rear or front will engage. Need to get the center locked in low on dirt or low traction surface and then move on to getting the others to lock. Keep in mind with the magic dial design, you can't lock the front without the rear locked. So center -> rear -> front (in which case all 3 will be locked)
Not sure where you are but if there are no dirt roads close by, and you have 4 reliable jackstands, put her on all four until 4 tires are suspended. Then engage the lockers and you'll see if they work... All four should be spinning at the same speed when engaged, and if unlocked, only one up front and one on rear will spin.
She pulled up and parked in front of my house today. She's mine and does she look great! I will be taking off two days this week and the detailing will begin with my son. He's warming up to it....
