This is all in the FAQ, but I'm a wordy guy.
I got the Longfield chrmoly birfield & axles kit. The birfields came prepacked. They also had a nifty machined aluminum gear shifter knob.
I Called Cruiserdan and told him what job I was doing. He rattled off the parts I would need. I also ordered a bunch of parts I was worried about breaking. I got an extra set of everything I would need to change out a birfield if I hosed it the first time. (Seals, etc...) Things went well on the front axle and now I'm building a field kit with the extra parts.
I opted to buy the bearings & everything from Dan. I understand that it is possible to source the bearings elsewhere cheaper, but I'd rather buy them from Dan and be 100% sure I got the right ones 8:00 day one.
I also ordered a bunch of parts I was worried about breaking. I highly recommend this. I knew I had one bad drive flange stud. I didn't know the name of it, but Dan faxed me a diagram and we figured it out. I ordered 3 drive flange studs, three extra nuts, three extra cone washer all for the drive flanges.
I also got new factory rotors & 100 series brake pads. If you're going to do this ever, this is the time to get it done.
I also got new dust caps (now it is obvious that they've been done), knuckle bearings...
I also ordered all of the parts to do the rear axle. We tore into that and figured out that my parking brake was rusted to where it had broken parts.
After we got the rear axle back together we realized we had parts left over from what Dan had sent us. We scratched our heads and threw them in the box. They were two rubber bands with a spring inside them. (Many of you can already guess the rest of the story.) The guy that helped me with the rebuild is a
mechanic. So... we didn't pay as much attention to the FSM as we probably should have. I now know how a 1 ton Dodge is set up as a full floater rear end with bearings bathed in gear lube. A day later it started to leak through the missing inner seals.
On the bright side, Dan was able to get me the replacement parking brake parts fast enough that we were able to fix the parking brake while we redid the rear axle work as a sealed off greased bearing unit.
I also changed the fluids in all 3 diffs. Dan sold me 6 hex keyed diff plugs & seals.
Total time? 3 days in the shop. Two of those were 12 hour days. We buffed all machined surfaces, so you could probably do it faster if you aren't as picky.
I'm glad it is done. No more clicking. I think we're going to do my wife's truck next fall. One of these a year is enough.
Dan's dogs have my yearly quota of dog food.
